23282 Discussions
[Solved] Problem with ig9icd64.dll
cris1343
Problem solved.
Hi
I'm developing a videogame in Java with no issue on testing it, but since yesterday it crashes inmediately when rendering 3D graphics with this error related to ig9icd64.dll
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ffc929e2d30, pid=15080, tid=0x000000000000216c
# JRE version: Java(TM) SE Runtime Environment (8.0_291-b10) (build 1.8.0_291-b10)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.291-b10 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C  [ig9icd64.dll+0x9d2d30]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
 It only happens on my laptop. I tried updating the Intel graphics driver to the latest version (27.20.100.9466) and nothing changed, also tried with 26.20.100.7325 and nothing.
I hope you can help me so I can continue developing my game
Sorry if I misspell something
Alberto_Sykes
cris1343, Thank you for posting in the Intel® Communities Support.
Perfect, it is great to know the problem was solved.
Any other inquiries, do not hesitate to contact us again.
Albert R.
