23839 Discussions
Specifications for the Intel ® HD Graphics 2500 driver
I'm Japanese.
Newly replaced Z77 i5-3470 motherboard and chipset, but a clean install (32bit) WindowsXPSP3,
Only install the graphics driver and chipset driver that is included in the CD accompanying the product, as shown in a balloon from the task tray
"This is the optimal resolution notification of detailed information. Appears not in the best resolution for the primary display device. Optimal resolution when clicked is 800 × 600. A" This notification is displayed.
Resolution is "800x600" as related to this problem, using the display switching unit.
Is improved as a way to eliminate this trouble, and to the third memory, from left to Hardware Acceleration slider in → Troubleshooting Advanced tab Properties → screen, for assistance graphic is lost, there is no meaning in this.
In the G41 chipset motherboard and AMD chipset, trouble does not occur.
About the monitor is capable of displaying up to 2048 × 1536 dots, to 80Hz.
On the device manager, other than a driver that is not installed! And marks are not included.
Connection cable of the display is the D-SUB15 pin.
The deal was carried out as follows, we will not lead to a fundamental improvement.
Installs all of the drivers and monitor information file all of the accompanying product CD
Tested in the same type of motherboard and CPU of the same type from a dealer
Direct connection or replace the display cable
BIOS Updates
Apply the latest drivers on the site of Intel and motherboard manufacturers
Have confirmed the <s...
Allan_J_Intel1
Hi k_takuya,
In order for all supported resolutions to be available, the monitor drivers need to be loaded. Contact the monitor manufacturer in order to obtain the .INF file to install the driver.
Check if you have loaded the latest graphics drivers at:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21824&lang=eng&OSVersion=Windows%20XP%20%20Professional*&DownloadType=Drivers http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21824&lang=eng&OSVersion=Windows%20XP%20%20Professional*&DownloadType=Drivers
For more information try this URL:
http://support.intel.com/support/graphics/sb/CS-022544.htm http://support.intel.com/support/graphics/sb/CS-022544.htm
Allan
This bug occurs regardless of the state of the inf file installation of the monitor.
Since there is no problem in the other motherboard chipset, is sure to be a bug in the driver.
I ask for immediate response.
It seems that this problem was improved by "Version 14. 51.10.5436" open to the public to 2013/01/21.&# 13; We wish to express our gratitude to the developer who solved this problem.&# 13; Thank you for reading poor sentences.&# 13; &# 13; Thanks very much.
