22827 Discussions
Star Wars KotOR I&II with Intel HD Graphics (Core i5/i7)
Hi All,
Since Kotor and Kotor II have come to steam some issues have arisen. One big one being that neither games work on my 2500K's graphics and I'm not the only one experiencing this. The problem is that the games will run, play the intro movies, briefly show a blank black screen, before crashing with a "kotor/kotor2 has stopped working" message. The fault module is always the intel graphics driver dll. I have played these games in the past on extremely old intel graphics chipsets from the pentium 4 era. The fact that they don't work on my 2500K's graphics is quite sad.
Here's the details of what happens.
Kotor I:
Problem signature:
Problem Event Name: APPCRASH
Application Name: swkotor.exe
Application Version: 1.0.3.0
Application Timestamp: 00000000
Fault Module Name: ig4icd32.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4fba7fae
Exception Code: c0000005
Exception Offset: 0074ec29
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 3081
Additional Information 1: be9b
Additional Information 2: be9bf493184e8a1cc6dbc11c84c53984
Additional Information 3: a099
Additional Information 4: a0997196efb56d84f9f4ce5a43974546
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Kotor II:
Problem signature:
Application Name: swkotor2.exe
Application Version: 2.2.0.0
Application Timestamp: 4226a88a
Locale ID: 3081
Additional Information 1: 7456
Additional Information 2: 745613ab99b452a52bfaab804110fcc1
Additional Information 3: 15b1
Additional Information 4: 15b104ca112f131f13e1e12c03b30f94
Can we get this fixed?
Allan_J_Intel1
hi,
Can you reply back with answers to the following questions?
What is the graphics driver version you are currently using on this computer?
Have you tested the latest version?
Operating system version?
There is a new driver available for your graphics controller; it was developed for win8 but works on win7 as well.
See here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Processor+graphics&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000 http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Processor+graphics&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000
Allan
I had used the latest version and previous version as suggested by someone on the Steam forums. Neither worked.
OS is windows 7 x64 ultimate.
I'll try that Win8 driver when I have a chance. I have my dedicated card back now though.
Hello there,
I've got the same problem to run those games.
Kotor 2's error:
Problem signature:
Fault Module Version: 9.17.10.2867
Fault Module Timestamp: 50634fef
Exception Offset: 0059e232
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 4108
Same problem here. I've got an Intel Core i3 2350M based laptop (HD 3000 graphics) and cannot run these games. I've heard that HD 4000 got a driver update with this problem fixed, but with the latest HD 3000 driver (version 9.17.10.3062) games still crash... Although the release dates are the same for both drivers and the only difference is version number (15.31.3.64.3071 for HD 4000).
disable fullscreen in the swkotor2.ini and see if that helps
tried still the same error.
Did you actually get to windowed mode or did it still start at fullscreen? I have the same problem with the integrated GPU and I get past the black screen in windowed, only problem is I can only get windowed to activate once per reinstall (of kotor 1 or 2). I spent some time looking around and several forums have discussed this (regarding all versions: retail cd, steam and "best of pc" edition) where the intel driver is concerned I found no solutions. As the HD3000 performance is crap in 1920x1200 and I need the game to start in fullscreen in order to get my discrete GPU running through lucid I have abandoned this.
MEA1
New Contributor II
Same problem here but with Oddworld - Stranger's Wrath HD (Intel HD 3000) - (Driver v9.17.10.3062) Win7 x64
Faulting application name: stranger.exe, version: 1.0.0.5, time stamp: 0x508ec117
Faulting module name: ig4icd32.dll, version: 9.17.10.2884, time stamp: 0x513a99d5
Exception code: 0xc0000005
Fault offset: 0x000011d9
Faulting process id: 0x16a4
Faulting application start time: 0x01ce3ea24357278b
Faulting application path: C:\GOG Games\Oddworld - Strangers Wrath\bin\stranger.exe
Faulting module path: C:\Windows\system32\ig4icd32.dll
Report Id: 899ad528-aa95-11e2-9138-5c9ad85a14ad
Allan_J_Intel1
Your issue has been escalated to our research department; I will post some updates about this matter.
NICHOLAS_F_Intel
@iyappi: The 3062 driver is worlds different from the 3071, so it is not just a numbering difference. That being said, the issue was supposed to be resolved in both drivers. Are you unable to run either KoToR 1 & 2, or just one of them? Can you test out the OEM provided Intel® Graphics display driver, and let me know if the issue still occurs with it (as well as the version/date of the OEM driver)? Additionally, can you provide a copy of your dxdiag? (Start -> Run -> dxdiag -> Save All Information).
@medo3000: The report you provided mentioned you were using the .2884 driver, not the 3062. Try completely uninstalling your graphics driver (deleting all related files if prompted), and re-installing the latest (.3062) driver, and let me know if the issue still occurs? Also, please provide a copy of your dxdiag (Start -> Run -> dxdiag -> Save All Information).
-Nic
MEA1
New Contributor II
@ allan_intel: Thank you for your reply.
@nic : Thank you too. I always do a clean install and i'm sure that the problem is the driver itself because i download the zip version of the driver and it contains version 9.17.10.2884 of (ig4icd32.dll) in the driver package. It looks like driver v9.17.10.3062 is packed with wrong dll version.
and here is my dxdiag :
System Information
Time of this report: 4/23/2013, 15:59:38
Machine name: MD-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130318-1533)
Language: English (Regional Setting: English)
System Manufacturer: FUJITSU
System Model: LIFEBOOK AH531/GFO
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 8192MB RAM
Available OS Memory: 8104MB RAM
Page File: 2168MB used, 14038MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 3000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_15EA10CF&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: SEC5641
Native Mode: 1366 x 768(p) (59.998Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.3062 (English)
Driver Version: 9.17.10.3062
DDI Version: 10.1
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 3/8/2013 19:10:18, 12615680 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4256-11CF-8978-E035B7C2C435}
Vendor ID: 0x8086
Device ID: 0x0116
SubSys ID: 0x15EA10CF
Revision ID: 0x0009
Driver Strong Name: oem2.inf:Intel.Mfg.NTamd64:iSNBM0:9.17.10.3062:pci\ven_8086&dev_0116
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YU...
MEA1
New Contributor II
NICHOLAS_F_Intel
Hi medo3000,
The issue has been forwarded off to the appropriate folks to take a look at. I'll let you know if/when there is news.
-Nic
MEA1
New Contributor II
BTrea
After trying many fixes I resolved the kotor 2 issue by installing the international version of the 1.0b patch from lucasarts. http://www.lucasarts.com/support/update/kotor2int.html LucasArts.com | Star Wars Knights of the Old Republic II: The Sith Lords
Hope this helps others as I spent WAY more time chasing wild geese before finding this.
