22643 Discussions
Status of Standard VGA Graphic Adapter is showing as not stared ?
BSing38
i have update adapter AMD Version 7650 got Standard VGA Graphic Adapter but it is not working why? please help.....
AlHill
This is an Intel problem?
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
n_scott_pearson
...And explain your problem better! So far it doesn't sounds like it is something that should be posted here at all.
Stefan3D
If you are talking about an old notebook with AMD 7650M / Intel hybrid graphics, you need a special hybrid driver from the manufacturer.
