23831 Discussions
Suddenly freezes??
Kalevinpelikanava
Hi, I thought I'd ask you for advice on what could be wrong with my Processor: Intel Core i5-13600KF. 3.5GHz, 24MB, LGA 1700
Motherboard:Gigabyte Z790 GAMING X AX
Memory:Kingston FURY Beast RGB DDR5-6000 C36 DC - 32GB
Graphics controller:Inno3D iChill GEFORCE RTX 3080 X4 LHR
SilverStone PF360-ARGB V2, 360mm AIO liquid cooling solution for processor
SSD:WD Black SN770 SSD 1TB NVMe M.2 Read speed 5150 MB/s
Case:DeepCool Matrexx 70
Power supply:(EVGA 850 BQ -ATX power supply, 850 W)
The machine is on and even when browsing the internet, the whole machine locks up, the screens freeze and the keyboard and mouse do not work at all, do they die completely?. It does not help when forced to start with the power button directly, the machine can sometimes work for hours and sometimes freezes and suddenly freezes??
bios is F13c gigabyte Z790 same problem has been going on for 2 weeks now, what comes to your mind?
Mike_Intel
Hello Kalevinpelikanava,
  1. Let me check, you are you reporting for Graphics or the processor?
  2. as it working fine before?
  3. If yes, what was the last change made in the system before the issue started?
  4. What are the troubleshooting steps that you tried so far?
  5. For me to review the hardware and the driver installed, please help generate the SSU logs of your system. Kindly refer to the link below for the steps:
Michael L.
Mike_Intel
Michael L.
Kalevinpelikanava
Hi Mike kalevi sihvonen here I am okay 🙂 the machine not so much the problem that the machine reports
NVIDIA App
Description
Faulting Application Path: C:\Program Files\NVIDIA Corporation\NVIDIA App\CEF\NVIDIA Overlay.exe
Creation Time: 25.2.2026 12.24.32
Problem: Operation interrupted
Status: Report sent
Problem signature
Problem Event Name: APPCRASH
Application name: NVIDIA Overlay.exe
Application version: 128.4.13.23
Application timestamp: 696a5d27
Faulting module name: libcef.dll
Faulting module version: 128.4.13.0
Faulting module timestamp: 66df642d
Exception code: 80000003
Exception exception: 0000000006ae1177
Extra information about the problem
Bucket ID: 5a25abd9bf26b1c60c91940969af864f (2058589272833754703)
NVIDIA Container
Description
Faulting Application Path: C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
Creation Time: 2/19/2026 19:19:19
Status: Report submitted
Problem signature
Application name: nvcontainer.exe
Application version: 1.48.3660.2504
Application timestamp: 68d67c21
Faulting module name: StackHash_1f64
Faulting module version: 10.0.26100.7824
Faulting module timestamp: c140bef4
Exception code: c0000374
Exception exception: PCH_7D_FROM_ntdll+0x00000000001625A4
Bucket ID: 740903bbf820862126c9737cb582d702 (1641970518611646210)
We've tried to fix this bug with Gemini Ai, but it seems to be a problem with the Nvidia drivers..
Kalevinpelikanava
Nowadays it does so that the machine is running, it just shuts down like that, but then that error message comes in the diagnostic data viewer where I can find what caused that crash or shutdown like that, I have tested the power supply, it is fine, there is no voltage or big jumps, it supplies a steady current, the EVGA 850w graphics card is that inno3d RTX 3080 2x8 pin with an additional power connector, there is no new connector yet, fortunately, which has been a nightmare for many, the processor can withstand stress programs, cinebench runs and the 3080 RTX can withstand it, it does not crash in the test..
Mike_Intel
Thank you for the update and detailed information.
Since the issue is with NVIDIA, have you tried to contact them regarding the error?
You may provide all the logs to NVIDIA for them to further investigate.
Michael L.
Mike_Intel
Michael L.
Kalevinpelikanava
Hi Mike, yes the machine is working now, today the latest nvidia driver came so tomorrow I will have to try either taking 3 monitors in the setup and raising the Hz up to 60hz up to 200hz. Thanks Mike for your help, have a good day
Mike_Intel
I am glad to hear that your system is working fine now.
Since there is no more issue with your system, I need to close this inquiry.
Michael L.
