23832 Discussions
Support for 480i CEA
HLe12
We have an adapter that convert HDMI to Component, the adapter support 480i CEA input. It has been tested and it work with a Raspberry Pi with the following config:
hdmi_group=1
hdmi_mode=6
We are trying to make it work with an Intel HD630 under Windows 10, but when we try to configure a custom resolution:
Select Display: Digital Television LONTIUM
With: 720
Height: 480
Refresh Rate: 60
Interlaced Mode: Enabled
Underscan Percentage: 0
Timing Standard: CEA 861
We received the following error message:
An Invalid value has been entered. Refer to the Manufacturer Manual to determine the supported value for this display.
Attached the information about the PC.
Can we make the HD630 work in 480i CEA?
HuyV
Hello huyv,
I understand that you are getting an error when trying to convert from HDMI to 480i CEA while using an adapter. Regarding this, Please bear in mind that Intel* does not recommend the use of any kind of adapters. This is because we cannot test all of them, so we cannot guarantee that these are going to work. We can recommend you to update your graphics driver, that in some cases will fix the problem
You can refer to the following link in order to download and install the latest driver for your current graphics controller:
https://downloadcenter.intel.com/download/27484/Graphics-Intel-Graphics-Driver-for-Windows-15-65-?product=98909 https://downloadcenter.intel.com/download/27484/Graphics-Intel-Graphics-Driver-for-Windows-15-65-?product=98909
David V
Hello huyv,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
HLe12
Hi David,
Unfortunately, updating to the latest driver didn't solve the issue.
I can't manually create a 480i CEA resolution.
I hope this can be solve in the GPU driver in a future release.
HuyV
Hello huyv,
Thank you for your response,
In order to better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
Also, bear in mind that there could be a hardware limitation issue here, either with the adapter and the compatibility with the Nuc.
David V
Hello huyv,
David V
