공지
23487 토론
Surface Pro 2, Display Port 2.1, Samsung U28D590 Combination Not 4K
BLang4
새로운 사용자
5,620 조회수
Hardware: Microsoft Surface Pro 2 w/docking station (different hardware)
CPU: Intel Core i5-4200U (different processor)
Monitor: SAMSUNG U28D590D
Intel Graphics Driver: 10.18.10.3621
Cable: Mini Display Port to Display Port v1.2
Actual Resolution: 2560 X 1440
Expected Resolution: 3200 X 2000 (no options for higher resolutions)
Screenshots
0 포인트
6 응답
Jose_H_Intel1
직원
4,534 조회수
Hi Brian_L, this is being investigated; we appreciate your patience.
0 포인트
BLang4
새로운 사용자
4,534 조회수
Thanks Joe,
I have updated the Microsoft thread I currently have open.
http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfdevice/surface-pro-2-display-port-21-samsung-u28d590/958b83a4-263a-4b70-ac9d-8f94a2d4ac30 Surface Pro 2, Display Port 2.1, Samsung U28D590 Combination Not 4K - Microsoft Community
0 포인트
ROBERT_U_Intel
4,534 조회수
Hi Brian
We are investigating the issue and will post updates on this thread.
Robert
0 포인트
ROBERT_U_Intel
4,534 조회수
Hi Brian
The maximum resolution that the Surface Pro 2 will support at 60Hz is 3200x2000. The Samsung U28D590D does not support 3200x2000 @ 60Hz.
However, the Surface Pro 2 will support 3840x2160 @ 30Hz and lower, but unfortunately the U28D590D does not support 3840x2160 @ 30Hz. It only supports 3840x2160 @ 59Hz and 60Hz.
So it will not be possible for you to display 3840x2160 @ 60Hz on the Surface Pro 2 or 3200x2000 @ 60Hz on the Samsung U28D590D.
Robert
BLang4
새로운 사용자
4,534 조회수
Thanks Robert,
Here are the links to the documentation that validates your assessment.
Samsung U28D590D: http://downloadcenter.samsung.com/content/UM/201403/20140305101006156/BN46-00410A-Eng.pdf Page 87, on the "Displayport" table, it states "VESA 2560 X 1440 at 59.951 Hz" and "VESA, 3840 X 2160 at 59.997 Hz".
Intel i5-4200U: https://software.intel.com/en-us/articles/quick-reference-guide-to-intel-processor-graphics Link, on the "Display and Audio Feature Comparison" section, it states "U-Processors: 3200 x 2000 @60 Hz, 3840x2160@30Hz"
Since the Samsung U28D590D is at 60 Hz and the Intel i5-4200U is at 30 Hz, it is clear that they are not compatible.
Thanks again!
Brian
0 포인트
Kevin_M_Intel
직원
4,534 조회수
0 포인트
응답
