23279 Discussions
Surface Pro 3 external monitor refresh rate
DSolo3
I would like to set the refresh rate to 60Hz on a Surface Pro 3 (Intel® Core™ i5-4300U Processor) connected to a ASUS PB287Q external monitor. I am using DisplayPort 1.2 with a Accell 1.2 certified cable (DP 1.2). I only see 30Hz refresh rate in the adapter setting for the monitor. The adapter type is Intel (R) HD Graphics Family. Its working at 3840 x 2160 at 30Hz but I would like it to run at 60Hz. The driver date is 18/12/2015. I can't find a later driver on the Intel site. I've tried the closest and the auto utility but they produce an error saying the driver doesn't match the adapter. Microsoft say the Surface Pro 3 with an i5 processor supports that resolution at 60Hz. The ASUS monitor is plug and play - there is no driver. Do you know if there is a later driver or whether its just not designed to do this.
DSolo3
Although Microsoft document that the i5 and i7 versions of the Surface Pro 3 support 3840 x 2160 at 60Hz, their support have confirmed that it will only go to 30Hz. Some of the SP4s will do this but not the SP3s
Hi DavidUK,
I am following your case. Let me know if I can help you with anything else.
Mike C
RFila
4K @ 60Hz is achieveable by MST (Multi Stream Transport) which stitches together two streams of half resolution 60Hz output to fill the full 4K monitor. To accomplish this you need a 4K monitor which specifically supports MST in.
4K @ 50Hz is achievable without MST, by the creation of a custom resolution in Intel's own driver (not Microsoft's version) which can be manually installed. However, since Windows 10 this has not been working due to Intel's Windows 10 driver removing the ability to specify the timing standard for a custom resolution. Further details are at /thread/77777 this post on this forum - it remains unsolved with no feedback from Intel.
Intel, please help!
Hi DavidUK,
Intel is still verifying the possibility to add the custom display resolution. It is necessary to work together with system manufacturers.
Mike C
RFila
Hi Mike C
Are you aware this was working perfectly in Intel's Display Driver for Windows 8.1? This problem has only arisen since you released drivers for Windows 10 which are missing this key functionality. If the driver can't be fixed can you let me know how I could install the Windows 8.1 driver on to Windows 10?
Richard
Hi RichardKT,
The custom display resolution setting in Intel® graphics control panel is not available on Windows 10. It is an OS limitation. Intel is already working with Microsoft on this but we don't have a estimated date for the resolution yet.
Windows 8.1 driver is not compatible with Windows10.
Mike C
RFila
Thanks for the update Mike C.
Hi RichardKT,
You are welcome.
Mike C
