22923 Discussions
I can't play WOW because the access to graphics hardware has been crashed, My laptop is new, it has Windows 10, RAM 4GB, HDD 1TB. Intel Core i5. What can I do?
CRive3
Hi, so time ago I can't play my game because when I try to log in a error appear :The graphics hardware has been crashed. I attached the DxDiag information. Thank you so much for your help. (sorry my english)
CCris2
New Contributor II
Hi Naev
Maybe you could provide the manufacturer and the model of your laptop ?
DxDiag is not attached ...
CRive3
Offourse! It's a HP Notebook-14-ac1431a, model P0E33LA- Thank you so much.
DxDiag
"System Information
Time of this report: 5/28/2016, 00:37:53
Machine name: CAMILA
Operating System: Windows 10 Home Single Language 64-bit (10.0, Build 10240) (10240.th1.150729-1800)
Language: Spanish (Regional Setting: Spanish)
System Manufacturer: HP
System Model: HP Notebook
BIOS: F.1A
Processor: Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz (4 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 4018MB RAM
Page File: 2437MB used, 2285MB available
Windows Dir: C:\Windows
DirectX Version: 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10240.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 520
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_1916&SUBSYS_8131103C&REV_07
Display Memory: 2137 MB
Dedicated Memory: 128 MB
Shared Memory: 2009 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP...
CCris2
New Contributor II
Hi Naev,
Please uninstall the driver you have now.
After you uninstall Intel Driver use this utility: http://www.guru3d.com/files-details/display-driver-uninstaller-download.html Display Driver Uninstaller Download version 15.7.5.5
Select Intel at Graphic Driver.
Then click on Clean and DO NOT Restart.
That will remove any leftovers from the old driver.
And then Set Automatic Installation Driver to default. And after that restart.
After that install the 64 bit driver from here: https://downloadcenter.intel.com/download/25957/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88355 Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40]
This is a generic beta driver and it may not work correctly on your system.
If you have some other problems you can also address to HP support page and see if they have other updated drivers and bios : http://support.hp.com/us-en/drivers HP Software and Driver Downloads for HP Printers, Laptops, Desktops and More | HP® Customer Support
Hi Naev,
Follow Ronin suggestions (post 3), they will help you to install the latest generic graphics driver from our website.
Mike C
