22660 Discusiones
Surface Pro 3 i7 (Intel HD5000) + ASUS PB287Q can't get over 30hz
MDell5
Principiante
2.157 Vistas
I've been trying hard over the last few days to find out why this isn't working. But I think I've finally run out of ideas.
My Surface Pro 3 is attached to my PB287Q over a mini display port to display port cable, my monitor is set to DP 1.2 under DisplayPort Stream and I'm running 10.18.10.3910 drivers.
I've tried reinstalling drivers, two different cables, monitor drivers and now more recently using Custommodeapp.exe to force 3840x2160, 32 Bit, 60p Hz, but I'm told that exceeds bandwidth capacity.
Attaching the monitor using an included cable to my desktop works just fine at 60, so I am wondering if this is something else I'm missing
I've tried two cables:
http://www.amazon.com/gp/product/B00A7R9I22/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 Amazon.com: Accell B143B-007J UltraAV Mini DisplayPort to DisplayPort 1.2 Cable with Latch, White, 6.6-Feet: Electronics
http://www.amazon.com/gp/product/B002XVYZ82/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 Amazon.com: StarTech 6-Feet Mini DisplayPort to DisplayPort Adapter Cable - M/M (MDP2DPMM6): Electronics
Oh and here's my info if this helps
Intel(R) HD Graphics 5000
Report Date: Wednesday, August 27, 2014
Report Time [hh:mm:ss]: 7:43:04 PM
Driver Version: 10.18.10.3910
Operating System: Windows* 8.1 Pro(6.3.9600)
Default Language: English (United States)
Installed DirectX* Version: 11.2
Supported DirectX* Version: 11.1
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.2
Physical Memory: 8097 MB
Processor: Intel(R) Core(TM) i7-4650U CPU @ 1.70GHz
Processor Speed: 2295 MHz
Vendor ID: 8086
Device ID: 0A26
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 5000
Video BIOS: 1215.0
Current Resolution: 3840 x 2160
* Devices connected to the Graphics Accelerator *
Active Displays: 1
Inactive Displays: 1
* Built-in Display *
Display Type: Digital
Serial Number: SEC3542
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 9.84 inches
Vertical Size: 6.69 inches
Supported Modes
2160 x 1440 (60p Hz)
2160 x 1440 (48p Hz)
* Digital Display *
Serial Number: ACI28a3
Gamma: 2.2
Connector Type: DisplayPort
Device Type: DisplayPort
Maximum Image Size
Horizontal Size: 24.41 inches
Vertical Size: 13.39 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (67p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (70p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 1024 (75p Hz)
1280 x 720 (50p Hz)
1280 x 960 (60p Hz)
1280 x 720 (60p Hz)
1280 x 1024 (60p Hz)
1440 x 576 (50p Hz)
1440 x 900 (60p Hz)
1440 x 480 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (50p Hz)
3840 x 2160 (30p Hz)
3840 x 2160 (60p Hz)
Power Management Support
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 04 69 A3 28 50 AD 01 00
15 18 01 04 A5 3E 22 78 3A 1C B5 A3 57 4F A0 27
0D 50 54 BF EF 00 D1 C0 81 40 81 80 95 00 B3 00
71 4F 81 C0 01 01 4D D0 00 A0 F0 70 3E 80 30 20
35 00 6D 55 21 00 00 1A 04 74 00 30 F2 70 5A 80
B0 58 8A 00 6D 55 21 00 00 1A 00 00 00 FD 00 1E
50 18 A0 3C 04 11 00 F0 F8 38 F0 3C 00 00 00 FC
00 41 53 55 53 20 50 42 32 38 37 51 0A 20 01 72
02 03 27 71 4F 01 02 03 11 12 13 04 14 05 1F 90
0E 0F 1D 1E 23 09 17 07 83 01 00 00 6A 03 0C 00
10 00 00 78 20 00 00 8C 0A D0 8A 20 E0 2D 10 10
3E 96 00 6D 55 21 00 00 18 01 1D 00 72 51 D0 1E
20 6E 28 55 00 6D 55 21 00 00 1E 01 1D 00 BC 52
D0 1E 20 B8 28 55 40 6D 55 21 00 00 1E 8C 0A D0
90 20 40 31 20 0C 40 55 00 6D 55 21 00 00 18 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EB
* Other names and brands are the property of their respective owners.
Thanks in advance!
0 kudos
1 Responder
ROBERT_U_Intel
Empleados
1.305 Vistas
Hi Mark
Here are the specs for the external display connection of the Surface Pro 3 (SP3) from the Surface Pro 3 Wiki. Thanks, Robert
External display connectivity
The Surface Pro 3 is capable of connecting up to two external displays. Maximum supported resolutions varies across laplet configurations according to CPU model. The i3-model can drive up to two http://en.wikipedia.org/wiki/WUXGA# WUXGA_.281920x1200.29 WUXGA (1920x1200 at 60 Hz) displays, while the i5 and i7 models support up to two external monitors with maximum resolution of 2880x1800 at 60 Hz. The maximum resolution of a single external display is 2560x1600 at 60 Hz for i3-based model and 3200x2000 at 60 Hz or 3840x2160 at 30 Hz (known as http://en.wikipedia.org/wiki/4K_resolution# Ultra_HD 4K Ultra HD) for i5 and i7-based models.http://en.wikipedia.org/wiki/Microsoft_Surface_Pro_3# cite_note-Haswell_HD_Graphics_Specs-23 [23]
So the SP3 does not support 3480x2160 60Hz, only at 30Hz. And the ASUS PB287Q does not support 3200x2000 resolutions or the 2560x1600 resolutions. So the max resolution you will be able to use with the SP3 and the PB287Q is 3480x2160 at 30 Hz.
Robert
Responder
