23832 Discussions
Test Driver for HDMI Display Detection Issues
ROBERT_U_Intel
In an ongoing effort to resolve HDMI display detection some users are experiencing, we are releasing a set of test drivers for Sandybridge, Ivybridge, Haswell, and Broadwell based graphics to gather feedback from the Intel Communities on resolving these issues. Some users have been able to resolve this issue by changing the display cable however, this may not solve the issue in all cases. These test drivers provide another option to address this issue.
These test drivers are exactly that, test drivers, and only for testing the HDMI display detection issues. Please be aware that these drivers should not be used on mission critical systems and that we recommend a restore point be created on your system before installing these test drivers.
These test drivers can be installed by extracting the zip file and running the setup.exe file or by using the "Have Disk" method to install.
According to the license agreement, these test drivers are provided "as is" and are not supported by Intel Technical Support or any other department at Intel.
Issues related or due to these drivers are not supported by Intel® Technical Support. However, we at Intel appreciate your feedback in this matter. Please post all feedback to this thread.
All versions of this test driver can be downloaded here: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24955 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24955
Which file to choose:
For 4th Generation Intel® Core™ Processors with Intel® HD Graphics 4200/4400/4600/5000/5100/5200/5300/5500/5600/6000/6200/6300
15.36.64bit_test.zip- Installs the 64bit Test Intel® Iris™ and HD graphics Driver 64-bit version for Haswell and Broadwell based products.
15.36.32bit_test.zip- Installs the 32bit Test Intel® Iris™ and HD graphics Driver 64-bit version for Haswell and Broadwell based products.
For 3rd Generation Intel® Core™ Processors with Intel® HD Graphics 2500/4000, use:
15.33.64bit_test.zip- Installs the 64bit Test Intel® and HD graphics Driver 64-bit version for Ivybridge based products.
15.33.32bit_test.zip- Installs the 32bit Test Intel® and HD graphics Driver 64-bit version for Ivybridge based products.
For 2nd Generation Intel® Core™ Processors with Intel® HD Graphics 3000/2000 , use:
15.28.64bit_test.zip- Installs the 64bit Test Intel® and HD graphics Driver 64-bit version
15.28.32bit_test.zip- Installs the 32bit Test Intel® and HD graphics Driver 64-bit version
Robert
SNovi
Tell my why the https://en.wikipedia.org/wiki/High-bandwidth_Digital_Content_Protection HDCP doesn't work after installation your 'experimental' driver?
So, now it is impossible to watch blue-ray disks as you know.
My current driver:
Name: Intel(R) HD Graphics manual-15.33-37859
Version: 10.18.10.4216
Date: 5/17/2015
The test driver is now live for 6 months. I would like to know if the HDMI detection fix is always only available in this test driver or if it has been ported in the latest stable drivers meaning today :
* 15.28.24.4229 for Sandy Bridge
* 15.33.39.4276 for Ivy Bridge
* 15.36.28.4332 for Haswell/Broadwell
* 15.40.10.4300 for Haswell/Broadwell/Skylake
Thanks for your help because it is frustrating to use yet this old test driver.
EstebanA_C_Intel
Hello:
Let me do a research on this to provide you with a resolution.
Esteban C
Bryce__Intel
Locking this thread.
For any unresolved issues, please search for your issue in the forums and provide the information in an existing thread using the guidelines below.
If it involves this thread, please create a new thread and reference this thread /thread/75262 https://communities.intel.com/thread/75262
If you've exhausted efforts searching without luck, then please create a new thread using the guidelines below. This will assist other community members to help you, or for Intel to review if needed. Appreciate your support in improving the driver and experience.
/thread/77761 Default level information for reporting Graphics issues
