22988 Discussions
The Intel integrated graphics driver cannot find the 75hz option using hdmi output.
number201724
I bought 2 nuc12wski7 and NUC12DCMi9, I found that when I use HDMI cable, I can't set 75hz refresh rate.
I use the same monitor, the same cable, plug it into an amd or nvidia graphics card and it can set 75hz correctly.
Whether it is the integrated graphics card of i9-12900 or the integrated graphics card of I7 1260P, the output of 75hz cannot be set under the windows platform.
intel graphics command center can recognize that the display supports 1080p 75hz, but it cannot be set.
But I can display 75hz correctly using ubuntu 22.04 linux.
Is there any solution please?
Monitor: ASUS PA247CV
Jean_Intel
Hello number201724,
  • When did the issue start?
  • Have you made sure that the issue persists when using another video port (Thunderbolt)?
  • Did you make sure that the unit is up to date? You can try using the Intel® DSA to scan your system for Intel driver and software updates.
I would recommend a clean installation of the graphics driver, as sometimes corrupted files from previous installations of drivers can linger on a system which can cause driver updates to not work as expected. Please, install the latest driver version available for your unit, 31.0.101.3222.
Jean O.
number201724
I've had this problem ever since I bought the NUC.
No problem with Thunderbolt, just hdmi.I have the same situation with multiple monitors.
Yes, I've tried reinstalling the latest drivers and the same thing happens with a complete removal of the drivers.
Jean_Intel
Hello number201724
Thanks for your response.
Please, create a report using the following software:
  • Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
  • Create a report using the Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
number201724
Attached is the diagnostic log
Jean_Intel
Hello number201724,
Jean O.
number201724
OK, looking forward to your reply. 🙂
Jean_Intel
Hello number201724,
Thanks for waiting for a response.
I have tested and tried this configuration and I can set up the system to 75Hz with no issues. It may indicate that the issue is a compatibility type issue between the display and the driver.
I would also suggest trying Asus Driver. In case the issue persists, I would recommend you try contacting Asus support.
Jean O.
number201724
Hello
I have the same problem with two PA247CV. This problem only occurs on intel graphics cards. I use amd and nvidia without this problem, and the same machine, linux can set 75hz.
Jean_Intel
Hello number201724,
Again, the problem seems to be due to a compatibility issue between the display and the driver. Based on this information I found an Asus driver for this display that you should try. In case the problem is still present after trying the driver, I recommend you contact Asus Support for further troubleshooting.
Jean O.
number201724
The asus driver is just a color profile. This is definitely a problem with the intel display driver. It is obvious that the mode supported by the monitor can be listed in the driver, but the user is not allowed to choose. Only 640x480 or 800x600 allows the use of 75hz, and if it is a problem with the monitor, then linux should not be able to choose. 1080p 75hz
1920 x 1080 (50p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (75p Hz)
Jean_Intel
Hello number201724,
I will resume my investigation. I will post back as soon as I have more details.
Jean O.
Jean_Intel
Hello number201724,
This time I would suggest you use IGCC and set up a custom resolution.
  • Open the Intel® Graphics Command Center:
  • From the Windows Start Menu, search for Intel Graphics Command Center. Click the Intel Graphics Command Center icon to open the application.
  • Click the Display tab. In the Display General Settings, click the Custom button located next to the Resolution setting.
  • A warning message will appear. Click Okay to proceed.
  • A new window will appear with Basic Custom Resolution settings. If desired, click Advanced Settings for more options.
  • Enter the custom resolution or mode values based on your requirements. Click Yes to accept the changes.
  • In the Resolution drop-down menu, scroll down and find the custom resolution along with an ‘X’ mark on the right side.
Jean O.
number201724
Hi, I didn't find advanced settings. It only has resolution (width and height)
Jean_Intel
Hello number201724,
Thanks for your reply.
The refresh rate option should be available below the width and height, as shown in the image attached. For more information, you can visit our article "How to Set Custom Resolutions and Modes in Intel® Graphics Command Center"
If your perspective regarding the Intel® Graphics Command Center is different than the one presented in the image, please provide me with a screenshot.
Jean O.
number201724
Hi Jean
Please check the screenshot, my IGCC is not the same as yours.
Jean_Intel
Hello number201724,
Thanks for the information you provided.
I will once again do further research regarding this matter. I will post back once I have more details and information to share.
Jean O.
Intel Customer Support Technician¿
Jean_Intel
Hello number201724,
Based on the information you have provided, it seems that this may be a driver issue in combination with this particular monitor since is working with Linux but not Windows.
Jean O.
number201724
Hello Jean
I think you need to escalate the issue to the driver development team to fix it because same monitor, same cable, same OS, nvidia(3080) and amd don't have this problem (6600xt and amd integrated graphics).
Jean_Intel
Hello number201724,
This information will be shared with the Intel Nuc team and we will work on this matter.
Jean O.
Jean_Intel
Hello number201724,
Please make sure that you are running the latest Windows updates. Select Start > Settings > Update & Security > Windows Update, then select Check for updates. Install any update requested by the Operating System if needed.
Also, it would ask you to run Monitor asset manager on your system and capture the screenshot (see sample attached). We need this to check the EDID version your monitor is running.
Jean O.
