23791 Discussions
The error while I'm using unreal engine 5.4.2
NootX2
I'm using Laptop NT950QED-KC72g
and while I using UE5 with Iris xe Graphics
I can see "missing supports for advanced rendering feature" error occur
and also I can see this event error411 happens too
also UE shutdowned when I change preview rendering level to sm6 although Intel graphic control center shows that my GPU supports sm6 and dx12
I hope Intel to do something about it
Senkuchan
Valued Contributor II
Have you try updating your graphics driver to check if there’s any changes? What is the model of your processor?
RonaldM_Intel
Hi @NootX2
Please share the Intel SSU report from your laptop so I can investigate if anything in the setup may be generating the issue. This report does not collect any personal information.
Is the error message occurring after performing any particular action in Unreal Engine 5? If you can provide with exact steps to reproduce the error that would be great.
Ronald M.
NootX2
sorry for late Mr.Ronald
the Missing Support for Advanced rendering  Feature occurs every time when I open UE editor
and UE editor shutdowned when I change rendering preview to SM6
RonaldM_Intel
Looking at the SSU I can see you are on an old graphics driver 31.0.101.3616.
Please do a clean driver installing using DDU and then install latest driver 32.0.101.5971.
If the issue continues with this new driver please add a screenshot of the error message and to facilitate reproduction - if possible - upload a sample project that I can import and see the issue.
Ronald M.
RonaldM_Intel
Hi again,
I would like to follow up with you and check the results after doing a clean installation of the latest driver 32.0.101.5972 using DDU.
If the issue persists with this driver please remember to include a screenshot of the error message and steps to facilitate reproduction - if possible - upload a sample project that I can import and see the issue.
Ronald M.
