告知
23459 ディスカッション
The folder you specified doesn't contain a compatible software driver for your device. if the folder contains a driver, make sure it is designed to work with windows for x64 based systems
ANahi
初心者
53,053件の閲覧回数
The folder you specified doesn't contain a compatible software driver for your device. if the folder contains a driver, make sure it is designed to work with windows for x64 based systems....
Why its show me? My operating system is windows 10 x64bit, I've checked so many times...
please solve this issue...
and reply fast..
0 件の賞賛
1 解決策
ANahi
初心者
47,621件の閲覧回数
I've also downloaded the software that you mentioned in your reply,but I dont know after collecting info than how should I send the file?! thats why I sent text and picture...those are collected via using Dxdiag & Intel® Driver &support assistant....
And I download this version driver
win64_24.20.100.6194
Driver Version: 24.20.100.6194
Release Version: Production Version
Release Date: July 10, 2018
Operating System(s):
Microsoft Windows* 10-64 - Creators Update
Microsoft Windows* 10-64 - Fall Creators Update
Microsoft Windows* 10-64 - April 2018 Update
Platforms:
6th Gen Intel(R) Core(TM) processor family (Codename Skylake)
7th Gen Intel(R) Core(TM) processor family (Codename Kaby Lake)
8th Gen Intel(R) Core(TM) processor family (Codename Kaby Lake-R, Coffee Lake)
Apollo Lake
Gemini Lake
元の投稿で解決策を見る
11 返答(返信)
n_scott_pearson
スーパーユーザー
47,620件の閲覧回数
To help you, we need a lot more information than this. What board/system? What processor? What driver(s) you have tried? What graphics hardware you have installed?
Run this utility and attach the results to a subsequent post: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Download Intel System Support Utility for Windows.
ANahi
初心者
47,620件の閲覧回数
ComputerGigabyte Technology Co., Ltd. B250M-HD3System ManufacturerGigabyte Technology Co., Ltd.System ModelB250M-HD3System TypeDesktopMotherboard ManufacturerGigabyte Technology Co., Ltd.Motherboard ProductB250M-HD3-CFBIOS VersionDefault System BIOSSMBIOS Version3.0Operating SystemMicrosoft Windows 10 Pro (64-bit)OS Build10.0.10240Build Branchth1_st1LocaleEnglish (United States)Windows DirectoryC:\WindowsSystem DirectoryC:\Windows\system32.NET Framework Versions2.0.50727.4927, 3.0.30729.4926, 3.5.30729.4926, 4.0.0.0, 4.6.00079Default Internet BrowserInternet Explorer 11.0.10240.17443Installed Internet BrowsersMozilla Firefox, Google Chrome, Internet Explorer 11.0.10240.17443, Opera StableProcessorIntel® Core™ i5-7400 CPU @ 3.00GHzManufacturerGenuineIntelDescriptionIntel64 Family 6 Model 158 Stepping 9Architecturex64# of Cores<td style="font-size: 0.875em; fo...
ANahi
初心者
47,619件の閲覧回数
I collect this information via intel® Driver & Support Assistant.
ANahi
初心者
47,622件の閲覧回数
Platforms:
Apollo Lake
Gemini Lake
n_scott_pearson
スーパーユーザー
47,619件の閲覧回数
In the lower right-hand corner of the edit window, you should see an Attach icon. If this icon is not present, there should be a button in the upper right-hand corner that says something like Use Advanced Editor; click on that and it should enable the Attach icon.
n_scott_pearson
スーパーユーザー
47,620件の閲覧回数
According to the data you've posted, the correct driver you should be downloading and installing is here: https://downloadcenter.intel.com/download/27892/Intel-Graphics-Driver-for-Windows-10?product=97147 Download Intel® Graphics Driver for Windows® 10. Is this the version you were trying to install?
ANahi
初心者
47,619件の閲覧回数
Yeah, This version,24.20.100.6194 you mentioned also, I got this message.
n_scott_pearson
スーパーユーザー
47,620件の閲覧回数
Just a guess (and yes, I am grasping at straws), but I think you may need to upgrade to a later update of Windows 10 before this install will work. It may not work with the original Creators Update. If I am right, you may have to back off to a much, much older version of the driver if you want to stick with the Creators Update.
ANahi
初心者
47,619件の閲覧回数
did you mean that I should go back the previous version of this driver?
ANahi
初心者
47,619件の閲覧回数
and I'm upgrading windows 10 latest version, after that, I'll try to reinstall this driver..if it's doesn't work..then I'll reply here...
ANahi
初心者
47,619件の閲覧回数
Thanks for helping me....
My problems are solved.,, after installing windows 10 most recent latest updates... you can close this thread.
返信
