23804 Discussions
The latest Graphics Driver cannot be installed.
JIABEI_C_Intel
I tried to install the latest Graphics Driver 15.26.12.64.2761 on my test board with i7-3770, win7 Enterprise 64bit, but got error 'computer does not meet the minimum requirement for installing the software'. It does work with Graphics Driver 15.26.8.64.2696. I also install the Graphics on i7-3610QE and E3-1285 v2
JIABEI_C_Intel
See same issue on i7-3610QE and E3-1285 v2
Is there anyone who has met with this problem?
MSchm21
Valued Contributor I
Have you tried the exe version of this driver? It should work with the i7-3770.
JIABEI_C_Intel
It solves the problem by using exe version.
I have the same problem with i7-3770, win7 pro 64. Mobo=Asus P8Z77-ID, 16GB Ram, Samsung 830 SSD. Currently running 8.15.10.2669. However,I have problems whenever using more advanced graphic functions (many different software). For example, doing ray-tracing in CAD package will always cause PC to crash after few seconds (non-responsive hang). Even refreshing windows experience index does not finish successfully. That is why I tried to upgrade. Uninstalling HD 4000 drivers fixes all crash issues.
I resolved the problem. I tried to force the driver installation but I got a message that driver is not compatible with "this version of windows". This was a clue. There was an issue with win7 that prevented SP1 from installing. After it did, everything is good.
