The latest drivers don`t support customized resolution for my Dell UltraSharp UP3214Q monitor, 4424 was the latest that worked, now I must first install 4424 and make the customized resolution and then install the latest driver
I would need the processor model or the Intel® graphics controller model. Also, the operating system version.
Allan.
CPU i7-4790k, graphic 4600, and windows 10 pro and using displayport cable
I did fresh Windows®10 patched to Anniversary update on Dell XPS 15 and latest driver version 4501.
https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496 https://downloadcenter.intel.com/download/26229/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen-?product=81496
I got custom resolution option. Please see attachments.
Allan.
4501 dont work, neither does beta driver 4539, it just says something like...
"customized resolution is not supported on this monitor" but it does work with 4424
Sorry to hear the driver version 4501 or the beta driver are not working on your computer. This driver is actually working on several systems around.
You will need to keep using driver version 4424 on your computer or try getting customized drivers from your computer manufacturer.
Do you have the possibility to test it on a Dell 4k UltraSharp UP3214Q monitor ???
I have tested the same graphics controller on HP Z27s
http://www8.hp.com/us/en/products/monitors/product-detail.html?oid=7128557# !tab=specs http://www8.hp.com/us/en/products/monitors/product-detail.html?oid=7128557# !tab=specs
Allan.
![](/skins/images/DC0E2679F7049B943291D1ED082A478E/responsive_peak/images/icon_anonymous_message.png)
