23091 Discussions
The performance of Palworld is quite poor.
lollipop816
I purchased an Arc B580 GPU and experienced terrible performance while playing Palworld. At 2K resolution with high settings, the frame rate only hovers around 60 FPS, with frequent 1% low frame drops below 10 FPS, resulting in an unplayable experience. Please help optimize this.
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
lollipop816
Thank you for your reply. The generated report is attached herewith for submission.
