22849 Discussions
The screen is glitching and showing weird dots
hnawayseh
Hello, I newly built a PC and I don't have a GPU yet, after installing windows I noticed weird dots on the screen and when I play videos I see glitches after that I lose the signal from screen for about 5 seconds.
I tried a gaming monitor and a normal TV and 2 HDMI cables and 1 DP and I updated everything on windows and the drivers, also I changed the refresh rate and the resolution and that didn't help
That's my specs:
- Intel i7-10700K
- MSI MPG Z490 Gaming Carbon WIFI
- Samsung 970 Evo Plus 1 TB
- Corsair Vengeance LPX (16*2) 3200 MHz
- Corsair HX1000 Platinum 1000 watt
- Corsair ICUE H115i RGB PRO XT
- Fractal Design Meshify C Case
- MSI 27" OPTIX 2k 165Hz
and I get a notification from windows after the signal come back you will see an attached photo of it
I searched a lot for this problem in the internet and I found nothing, I hope to find some help here and to know what's causing this
problem is it the CPU or MB or it's a software problem
Sebastian_M_Intel
Hello hnawayseh,
Thank you for posting on the Intel® communities.
So we can better assist you, please provide the following:
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
  • Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
  • Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. Provide the Report for Intel® Graphics Drivers, follow this link
Sebastian M
Intel Customer Support Technician
Sebastian_M_Intel
Hello hnawayseh,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
hnawayseh
There was a problem with my CPU I changed it and now everything is good, thanks for the help.
Sebastian_M_Intel
Hello hnawayseh,
Thank you for your update.
Based on that, we will proceed to close this inquiry. If you have additional questions, please submit a new thread and we will gladly assist you.
Sebastian M
