22665 Discussions
ThinkPad T15p Gen 2i cannot output 1440p
afonsoguima
Hi everyone,
I just bought a new monitor which is 1440p that I'm not able to use at full power because my ThinkPad T15p Gen 2i cannot output 1440p with HDMI, at least I'm not able to.
Steps taken:
1.  2560 * 1440 as been set on both Windows Display Settings and Intel Control Graphic Center (I have my computer in another language don't know the actual name of the application), and it shows as indicated bellow with black bars and the actual image being weird.1440perror.jpg
2. Bought a new 2.1 HDMI cable and it is not from that (tried 3 different ones with the same output)
3. My other laptop wasn't able to output 1440p through HDMI but since it had DP I used that one so monitor is fine (thinkpad only has HDMI and a USB-C for charging).
4. NVIDIA settings do not have the display settings.
5. My laptop has a i7-11800H so it should also be able to output it.
What can I do next?
afonsoguima
Anyone help?
Jean_Intel
Hello afonsoguima,
  • Have you tried installing the latest Graphics driver? There are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, that are customized to work with each specific system. The best thing to do is to use the drivers provided by the system manufacturer (OEM) However you can also try using our Intel® Driver & Support Assistant (Intel® DSA) which will help you keep your system up to date; you should know that the Intel® DSA installs Intel generics drivers
  • Also, I would ask you to create a report using the following applications:
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
afonsoguima
Hi jean,
Thanks for the response. First, yes I did install the latest drivers using the Intel DSA tool but with no luck, the problem persists. As for the reports here they are:
  1.
    Report Date: Tuesday, 06 September 2022
    Report Time [hh:mm:ss]: 02:24:17 PM
    Operating System: Microsoft Windows 10 Enterprise 10.0.19044
    IGCC Version: 1.100.3408.0
    Language: pt-PT
    Physical Memory: 31.73 GB
    Current Resolution: 2560x1080
    Processor: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
    Processor Speed: 2304 MHz
    GFX Driver Name: NVIDIA GeForce GTX 1650 with Max-Q Design
    Shader Version: NA
    OpenCL* Version: NA
    * Microsoft DirectX* *
    Runtime Version: NA
    Hardware-Supported Version: NA
    Vendor ID: 10DE
    Device ID: 1F99
    Device Revision: A1
    GFX Driver Version: 30.0.15.1329
    Dedicated RAM: 4 GB
    Shared RAM: 16 GB
    Max Supported Displays: NA
    GFX Vulcan:
    GFX Driver Name: Intel® UHD Graphics
    Shader Version: 5.1
    OpenCL* Version: 0
    Runtime Version: 12
    Hardware-Supported Version: 12
    Vendor ID: 8086
    Device ID: 9A60
    Device Revision: 01
    GFX Driver Version: 31.0.101.3413
    Dedicated RAM: 0 GB
    Shared RAM: 16 GB
    Max Supported Displays: 4
    GFX Vulcan: 1.3.224
    GFX GOP: 17.0.1061
    * Devices connected to the Graphics Accelerator *
    Active Displays: 2
    * Digital Display 1 *
    Display Name: Ecrã incorporado
    Display Type: Digital
    Serial Number: -
    DDC2 Protocol: Suportado
    Gamma: 2.2
    Connector Type: DisplayPort
    Maximum Image Size
    Horizontal – 13.39 polegadas
    Vertical – 7.48 polegadas
    Supported Modes
    1920 x 1080 (60p Hz)
    Power Management Support
    Modo de espera suportado
    Modo de suspensão suportado
    Modo de inatividade suportado
    Raw EDID:
    00 FF FF FF FF FF FF 00 30 AE BA 40 00 00 00 00
    00 1E 01 04 A5 22 13 78 E2 28 65 97 59 54 8E 27
    1E 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
    01 01 01 01 01 01 36 36 80 A0 70 38 20 40 44 2D
    35 00 58 C1 10 00 00 18 00 00 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 D1
    09 3C D1 09 3C 1E 0A 00 0D AE 1E 15 00 00 00 FE
    00 4E 31 35 36 48 43 41 2D 45 41 43 0A 20 00 DF
    * Digital Display 2 *
    Display Name: HP X34
    Serial Number: 6CM14806TZ
    Gamma: 2.2
    Maximum Image Size
    Horizontal – 31.5 polegadas
    Vertical – 13.39 polegadas
    Supported Modes
    640 x 480 (60p Hz)
    640 x 480 (75p Hz)
    720 x 400 (70p Hz)
    720 x 480 (60p Hz)
    800 x 600 (60p Hz)
    1024 x 768 (60p Hz)
    1280 x 720 (60p Hz)
    1280 x 800 (60p Hz)
    1280 x 1024 (60p Hz)
    1440 x 900 (60p Hz)
    1600 x 900 (60p Hz)
    1680 x 1050 (60p Hz)
    1920 x 1080 (100p Hz)
    1920 x 1200 (60p Hz)
    2560 x 1080 (60p Hz)
    2560 x 1440 (60p Hz)
    3440 x 1440 (60p Hz)
    3440 x 1440 (75p Hz)
    3440 x 1440 (100p Hz)
    Raw EDID:
    00 FF FF FF FF FF FF 00 22 0E 29 37 01 01 01 01
    30 1F 01 03 80 50 22 78 2A 0C 35 A9 56 4D 9B 24
    0D 50 54 A1 08 00 D1 C0 B3 00 A9 C0 D1 00 95 00
    81 80 81 00 81 C0 4F 7D 70 AA D0 A0 29 50 30 20
    3A 00 20 4F 31 00 00 1A 00 00 00 FD 00 30 64 1E
    9B 37 00 0A 20 20 20 20 20 20 00 00 00 FC 00 48
    50 20 58 33 34 0A 20 20 20 20 20 20 00 00 00 FF
    00 36 43 4D 31 34 38 30 36 54 5A 0A 20 20 01 B3
    02 03 3B F1 47 10 40 5A 04 03 02 01 23 09 07 07
    83 01 00 00 67 03 0C 00 10 00 38 42 67 D8 5D C4
    01 78 80 00 68 1A 00 00 01 01 30 64 ED E3 05 E0
    01 E6 06 07 01 60 5A 33 E2 00 EB CC 9D 70 AA D0
    A0 34 50 30 20 3A 00 20 4F 31 00 00 1A EF D4 70
    AA D0 A0 46 50 30 20 3A 00 20 4F 31 00 00 1A 56
    5E 00 A0 A0 A0 29 50 30 20 35 00 20 4F 31 00 00
    1A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 13
    * Other names and brands are the property of their respective owners.
  2. # SSU Scan Information
    Scan Info:
    Version:"2.5.0.15"
    Date:"09/06/2022"
    Time:"00:00:26.1552629"
    # Scanned Hardware
    Computer:
    BaseBoard Manufacturer:"LENOVO"
    BIOS Mode:"UEFI"
    BIOS Version/Date:"LENOVO N38ET33W (1.14 ) , 08/04/2022 12:00"
    CD or DVD:"Not Available"
    Embedded Controller Version:"1.11"
    Platform Role:"Mobile"
    Processor:"11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz , GenuineIntel"
    Secure Boot State:"On"
    SMBIOS Version:"3.2"
    Sound Card:"Intel® Smart Sound Technology for USB Audio"
    Sound Card:"Intel® Smart Sound Technology for Digital Microphones"
    Sound Card:"Intel® Smart Sound Technology for Bluetooth® Audio"
    Sound Card:"USB Audio Device"
    Sound Card:"Realtek High Definition Audio(SST)"
    System Manufacturer:"LENOVO"
    System Model:"21A8S00X00"
    System SKU:"LENOVO_MT_21A8_BU_Think_FM_ThinkPad T15p Gen 2i"
    System Type:"x64-based PC"
    - "Display"
    Intel ® Graphics Driver Version:"Not Available"
    - "Intel(R) UHD Graphics"
    Adapter Compatibility:"Intel Corporation"
    Adapter DAC Type:"Internal"
    Adapter RAM:"1,00 GB"
    Bits Per Pixel:"32"
    - "Caption":"Intel(R) UHD Graphics"
    Link:"http://www.intel.com/content/www/us/en/search.html?keyword=UHD+Graphics"
    CoInstallers:"oem48.inf,iTGLD_w10_DS,Internal,Intel(R) UHD Graphics Family"
    Color Table Entries:"4294967296"
    Dedicated Video Memory:"Not Available"
    Driver:"igdkmdn64.sys"
    Driver Date:"08/19/2022 01:00"
    Driver Path:"C:\windows\system32\DriverStore\FileRepository\iigd_dch.inf_amd64_e684c1b7a952918f\igdkmdn64.sys"
    Driver Provider:"Intel Corporation"
    Driver Version:"31.0.101.3413"
    INF:"oem48.inf"
    INF Section:"iTGLD_w10_DS"
    Install Date:"Not Available"
    Installed Drivers:"C:\windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_e684c1b7a952918f\igdumdim64.dll,C:\windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_e684c1b7a952918f\igd10iumd64.dll,C:\windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_e684c1b7a952918f\igd10iumd64.dll,C:\windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_e684c1b7a952918f\igd12umd64.dll"
    Last Error Code:"Not Available"
    Last Error Code Description:"Not Available"
    Last Reset:"Not Available"
    Manufacturer:"Intel Corporation"
    Microsoft DirectX* Version:"DirectX 12"
    Monochrome:"No"
    Number of Colors:"4294967296"
    Number of Video Pages:"Not Available"
    PNP Device ID:"PCI\VEN_8086&DEV_9A60&SUBSYS_22DA17AA&REV_01\3&11583659&1&10"
    Power Management Capabilities:"Not Available"
    Power Management Supported:"Not Available"
    Refresh Rate - Current:"60 Hz"
    Refresh Rate - Maximum:"60 Hz"
    Refresh Rate - Minimum:"60 Hz"
    Resolution:"1920 X 1080"
    Scan Mode:"Noninterlaced"
    Service Name:"igfxn"
    Status:"OK"
    Video Architecture:"VGA"
    Video Memory:"Unknown"
    Video Processor:"Intel(R) UHD Graphics Family"
    - "NVIDIA GeForce GTX 1650 with Max-Q Design"
    Adapter Compatibility:"NVIDIA"
    Adapter DAC Type:"Integrated RAMDAC"
    Adapter RAM:"4,00 GB"
    Availability:"Offline"
    Bits Per Pixel:"Not Available"
    Caption:"NVIDIA GeForce GTX 1650 with Max-Q Design"
    CoInstallers:"oem137.inf,Section193,Integrated RAMDAC,NVIDIA GeForce GTX 1650 with Max-Q Design"
    Color Table Entries:"Not Available"
    Driver:"nvlddmkm.sys"
    Driver Date:"06/22/2022 01:00"
    Driver Path:"C:\windows\system32\DriverStore\FileRepository\nvlt.inf_amd64_922792e2d39c47ae\nvlddmkm.sys"
    Driver Provider:"NVIDIA"
    Driver Version:"30.0.15.1329"
    INF:"oem137.inf"
    INF Section:"Section193"
    Installed Drivers:"C:\windows\System32\DriverStore\FileRepository\nvlt.inf_amd64_922792e2d39c47ae\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nvlt.inf_amd64_922792e2d39c47ae\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nvlt.inf_amd64_922792e2d39c47ae\nvldumdx.dll,C:\windows\System32\DriverStore\FileRepository\nvlt.inf_amd64_922792e2d39c47ae\nvldumdx.dll"
    Manufacturer:"NVIDIA"
    Monochrome:"No"
    Number of Colors:"Not Available"
    PNP Device ID:"PCI\VEN_10DE&DEV_1F99&SUBSYS_22DA17AA&REV_A1\4&1140022&0&0008"
    Refresh Rate - Current:"Not Available"
    Refresh Rate - Maximum:"Not Available"
    Refresh Rate - Minimum:"Not Available"
    Resolution:"Not Available"
    Scan Mode:"Not Available"
    Service Name:"nvlddmkm"
    Status:"OK"
    Video Processor:"NVIDIA GeForce GTX 1650 with Max-Q Design"
    - "Memory"
    Physical Memory (Available):"13,25 GB"
    Physical Memory (Installed):"32 GB"
    Physical Memory (Total):"31,73 GB"
    - "BANK 0"
    Capacity:"32 GB"
    Channel:"Controller1-ChannelA-DIMM0"
    Configured Clock Speed:"3200 MHz"
    Configured Voltage:"1200 millivolts"
    Data Width:"64 bits"
    Form Factor:"SODIMM"
    Interleave Position:"Not Available"
    Manufacturer:"SK Hynix"
    Maximum Voltage:"Not Available"
    Memory Type:"Unknown"
    Minimum Voltage:"Not Available"
    Part Number:"HMAA4GS6CJR8N-XN"
    Serial Number:"54F5CF85"
    Status:"Not Available"
    Type:"Synchronous"
    - "Motherboard"
    BIOS:"N38ET33W (1.14 ), LENOVO - 1140"
    Caption:"Motherboard"
    Chipset:"Not Available"
    Date:"04/08/2022 01:00"
    Model:"Not Available"
    Part Number:"Not Available"
    PNP Device ID:"ACPI\PNP0C01\2&DABA3FF&1"
    Product:"21A8S00X00"
    Serial Number:"L1HF21T045Z"
    Status:"OK"
    Version:"SDK0J40697 WIN"
    - "Networking"
    Intel ® Network Connections Install Options:"Not Available"
    Intel ® Network Connections Version:"Not Available"
    Intel ® PROSet/Wireless Software Version:"Not Available"
    - "Barracuda Virtual Adapter (VPN)"
    Caption:"Barracuda Virtual Adapter (VPN)"
    CoInstallers:"Not Available"
    Default IP Gateway:"Not Available"
    DHCP Enabled:"Yes"
    DHCP Lease Expires:"Not Available"
    DHCP Lease Obtained:"Not Available"
    DHCP Server:"Not Available"
    Driver:"cudavpn.sys"
    Driver Date:"09/07/2020 12:00"
    Driver Path:"C:\windows\system32\drivers\cudavpn.sys"
    Driver Provider:"Barracuda Networks, Inc."
    Driver Version:"5.2.0.2"
    Index:"0014"
    INF:"oem84.inf"
    INF Section:"cudavpn.10.0.x64"
    Installed:"Yes"
    IP Address:"Not Available"
    IP Subnet:"Not Available"
    Last Reset:"09/06/2022 02:20"
    MAC Address:"50:48:49:4F:4E:43"
    Manufacturer:"Barracuda Networks, Inc."
    Media Type:
    Net Connection ID:"Ethernet 2"
    NetCfgInstanceId:"{B3AF6C89-5565-447B-A18E-312B45473781}"
    Number of VLANs:"0"
    PNP Device ID:"ROOT\CUDAVPN\0000"
    Port:"Not Available"
    Power Management (Low Power):"Not Available"
    Power Management (Wake On LAN):"Not Available"
    Power Management (Wake on Magic Packet):"Not Available"
    Power Management Supported:"No"
    Product Type:"Barracuda Virtual Adapter (VPN)"
    Service Name:"cudavpn"
    Status:"Enabled"
    Team Name:"Not in a team"
    Temperature:
    Type:"Ethernet 802.3"
    - "Service Bindings"
    Client for Microsoft Networks:
    File and Printer Sharing for Microsoft Networks:
    FortiClient NDIS 6.3 Packet Filter Driver:
    Internet Protocol Version 4 (TCP/IPv4):
    Internet Protocol Version 6 (TCP/IPv6):
    Link-Layer Topology Discovery Mapper I/O Driver:
    Link-Layer Topology Discovery Responder:
    Microsoft LLDP Protocol Driver:
    QoS Packet Scheduler:
    - "Settings"
    LinkSpeed:Link Speed:"1.0 Gbps (2)"
    MTU:Max. Transmission Unit (MTU):"1430 (1430)"
    - "Bluetooth Device (Personal Area Network)"
    Caption:"Bluetooth Device (Personal Area Network)"
    DHCP Enabled:"Yes"
    Driver:"bthpan.sys"
    Driver Date:"06/21/2006 12:00"
    Driver Path:"C:\windows\system32\drivers\bthpan.sys"
    Driver Provider:"Microsoft"
    Driver Version:"10.0.19041.1"
    Index:"0003"
    INF:"bthpan.inf"
    INF Section:"BthPan.Install"
    Installed:"Yes"
    MAC Address:"F0:57:A6:04:E6:BE"
    Manufacturer:"Microsoft"
    Media Type:
    Net Connection ID:"Bluetooth Network Connection"
    NetCfgInstanceId:"{CBD45BF2-AFE6-4D5D-8A39-21B0A0892E96}"
    Number of VLANs:"0"
    PNP Device ID:"BTH\MS_BTHPAN\6&90ADCA3&0&2"
    Product Type:"Bluetooth Device (Personal Area Network)"
    Service Name:"BthPan"
    Status:"Enabled"
    Temperature:
    - "Fortinet SSL VPN Virtual Ethernet Adapter"
    Caption:"Fortinet SSL VPN Virtual Ethernet Adapter"
    Default IP Gateway:"192.168.130.105"
    DHCP Enabled:"No"
    Driver:"ftsvnic.sys"
    Driver Date:"10/29/2021 12:00"
    Driver Path:"C:\windows\system32\drivers\ftsvnic.sys"
    Driver Provider:"Fortinet Inc"
    Driver Version:"2021.10.29.0"
    Index:"0016"
    INF:"oem120.inf"
    INF Section:"ftsvnic.ndi"
    Installed:"Yes"
    IP Address:"192.168.130.104;fe80::f859:d35d:33cd:b445"
    IP Subnet:"255.255.255.255;64"
    MAC Address:"00:09:0F:AA:00:01"
    Manufacturer:"Fortinet Inc"
    Media Type:
    Net Connection ID:"Ethernet 4"
    NetCfgInstanceId:"{BE42A499-93C4-48FC-8039-A3926721870A}"
    Number of VLANs:"0"
    PNP Device ID:"ROOT\NET\0001"
    Product Type:"Fortinet SSL VPN Virtual Ethernet Adapter"
    Service Name:"ftsvnic"
    Status:"Enabled"
    Temperature:
    - "Fortinet Virtual Ethernet Adapter (NDIS 6.30)"
    Caption:"Fortinet Virtual Ethernet Adapter (NDIS 6.30)"
    DHCP Enabled:"Yes"
    Driver:"ftvnic.sys"
    Driver Date:"09/04/2020 12:00"
    Driver Path:"C:\windows\system32\drivers\ftvnic.sys"
    Driver Provider:"Fortinet"
    Driver Version:"2020.4.9.0"
    Index:"0015"
    INF:"oem119.inf"
    INF Section:"FTNT.ndi"
    Installed:"Yes"
    MAC Address:"00:09:0F:FE:00:01"
    Manufacturer:"Fortinet"
    Media Type:
    Net Connection ID:"Ethernet 3"
    NetCfgInstanceId:"{31DB8F06-91FE-47A9-8C68-43BB1F56B414}"
    Number of VLANs:"0"
    PNP Device ID:"ROOT\NET\0000"
    Product Type:"Fortinet Virtual Ethernet Adapter (NDIS 6.30)"
    Service Name:"ft_vnic"
    Status:"Enabled"
    Temperature:
    - "Intel(R) Ethernet Connection (14) I219-V"
    - "Caption":"Intel(R) Ethernet Connection (14) I219-V"
    Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Ethernet+Connection+(14)+I219+V"
    DHCP Enabled:"Yes"
    Driver:"e1d68x64.sys"
    Driver Date:"06/22/2021 12:00"
    Driver Path:"C:\windows\system32\DriverStore\FileRepository\e1d68x64.inf_amd64_b32d0891eb98aee4\e1d68x64.sys"
    Driver Provider:"Intel"
    Driver Version:"12.19.1.37"
    ETrackID:"Not Available"
    Index:"0002"
    INF:"oem2.inf"
    INF Section:"E15FA.10.0.1.19H1"
    Installed:"Yes"
    MAC Address:"88:A4:C2:6C:7E:9F"
    Manufacturer:"Intel"
    Media Type:
    Net Connection ID:"Ethernet"
    NetCfgInstanceId:"{21F32296-B688-439C-81B6-84523AAE5851}"
    Number of VLANs:"0"
    NVM Version:"Not Available"
    Part Number:"FFFFFF-0FF"
    PNP Device ID:"PCI\VEN_8086&DEV_15FA&SUBSYS_22D717AA&REV_11\3&11583659&1&FE"
    Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
    Product Type:"Intel(R) Ethernet Connection (14) I219-V"
    Service Name:"e1dexpress"
    Status:"Enabled"
    Temperature:
    - "Settings"
    *FlowControl:Flow Control:"Rx & Tx Enabled (3)"
    *InterruptModeration:Interrupt Moderation:"Enabled (1)"
    *IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
    *JumboPacket:Jumbo Packet:"Disabled (1514)"
    *LsoV2IPv4:Large Send Offload V2 (IPv4):"Enabled (1)"
    *LsoV2IPv6:Large Send Offload V2 (IPv6):"Enabled (1)"
    *ModernStandbyWoLMagicPacket:Wake from S0ix on Magic Packet:"Enabled (1)"
    *NumRssQueues:Maximum Number of RSS Queues:"2 Queues (2)"
    *PMARPOffload:Protocol ARP Offload:"Enabled (1)"
    *PMNSOffload:Protocol NS Offload:"Enabled (1)"
    *PriorityVLANTag:Packet Priority & VLAN:"Packet Priority & VLAN Enabled (3)"
    *PtpHardwareTimestamp:PTP Hardware Timestamp:"Disabled (0)"
    *ReceiveBuffers:Receive Buffers:"256 (256)"
    *RSS:Receive Side Scaling:"Enabled (1)"
    *RSSProfile:RSS load balancing profile:"ClosestProcessor (1)"
    *SelectiveSuspend:Selective Suspend:"Enabled (1)"
    *SoftwareTimestamp:Software Timestamp:"Disabled (0)"
    *SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
    *SSIdleTimeout:Selective Suspend Idle Timeout:"20 (20)"
    *TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
    *TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
    *TransmitBuffers:Transmit Buffers:"512 (512)"
    *UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
    *UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
    *WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
    *WakeOnPattern:Wake on Pattern Match:"Enabled (1)"
    AdaptiveIFS:Adaptive Inter-Frame Spacing:"Disabled (0)"
    AutoPowerSaveModeEnabled:Link Speed Battery Saver:"Disabled (0)"
    EEELinkAdvertisement:Energy Efficient Ethernet:"On (1)"
    EnablePME:Enable PME:"Enabled (1)"
    ITR:Interrupt Moderation Rate:"Adaptive (65535)"
    LinkNegotiationProcess:Legacy Switch Compatibility Mode:"Disabled (1)"
    LogLinkStateEvent:Log Link State Event:"Enabled (51)"
    MasterSlave:Gigabit Master Slave Mode:"Auto Detect (0)"
    ReduceSpeedOnPowerDown:Reduce Speed On Power Down:"Enabled (1)"
    SipsEnabled:System Idle Power Saver:"Disabled (0)"
    ULPMode:Ultra Low Power Mode:"Enabled (1)"
    WaitAutoNegComplete:Wait for Link:"Auto Detect (2)"
    WakeOnLink:Wake on Link Settings:"Disabled (0)"
    - "Intel(R) Wi-Fi 6 AX201 160MHz"
    Access Point:"50:5d:ac:88:22:d4"
    Authentication:"WPA2-Personal"
    - "Caption":"Intel(R) Wi-Fi 6 AX201 160MHz"
    Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Wi+Fi+6+AX201+160MHz"
    Channel:"100"
    Cipher:"CCMP"
    Connection Mode:"Auto Connect"
    Default IP Gateway:"192.168.1.1;fe80::1"
    DHCP Enabled:"Yes"
    DHCP Lease Expires:"09/06/2022 03:52"
    DHCP Lease Obtained:"09/06/2022 02:52"
    DHCP Server:"192.168.1.1"
    Driver:"Netwtw10.sys"
    Driver Date:"08/14/2022 12:00"
    Driver Path:"C:\windows\system32\drivers\Netwtw10.sys"
    Driver Version:"22.160.0.4"
    Index:"0001"
    INF:"oem169.inf"
    INF Section:"Install_GEN_QSR_HrP2_201_AX_2x2_WinT_non_6e"
    Installed:"Yes"
    IP Address:"192.168.1.162;fe80::edd1:3e35:e8a1:8eeb;2001:818:df5a:4400:f1ee:41d3:c8b3:6456;2001:818:df5a:4400:edd1:3e35:e8a1:8eeb"
    IP Subnet:"255.255.255.0;64;128;64"
    MAC Address:"F0:57:A6:04:E6:BA"
    Media Type:
    Net Connection ID:"WiFi"
    NetCfgInstanceId:"{9902897F-A229-4C9C-B9AB-C120EF597ECC}"
    Network Name:"Guima-House"
    Network Type:"Infrastructure"
    Number of VLANs:"0"
    PNP Device ID:"PCI\VEN_8086&DEV_43F0&SUBSYS_00708086&REV_11\3&11583659&1&A3"
    Product Type:"Intel(R) Wi-Fi 6 AX201 160MHz"
    Profile:"Guima-House"
    Radio Type:"802.11ac"
    Receive Rate:"866.7 Mbps"
    Service Name:"Netwtw10"
    Signal Strength:"85%"
    State:"connected"
    Status:"Enabled"
    Temperature:
    Transmit Rate:"866.7 Mbps"
    - "Settings"
    *DeviceSleepOnDisconnect:Sleep on WoWLAN Disconnect:"Disabled (0)"
    *PacketCoalescing:Packet Coalescing:"Enabled (1)"
    *PMARPOffload:ARP offload for WoWLAN:"Enabled (1)"
    *PMNSOffload:NS offload for WoWLAN:"Enabled (1)"
    *PMWiFiRekeyOffload:GTK rekeying for WoWLAN:"Enabled (1)"
    ChannelWidth24:Channel Width for 2.4GHz:"Auto (1)"
    ChannelWidth52:Channel Width for 5GHz:"Auto (1)"
    CtsToItself:Mixed Mode Protection:"RTS/CTS Enabled (0)"
    FatChannelIntolerant:Fat Channel Intolerant:"Disabled (0)"
    IbssTxPower:Transmit Power:"5. Highest (100)"
    IEEE11nMode:802.11n/ac/ax Wireless Mode:"4. 802.11ax (3)"
    MIMOPowerSaveMode:MIMO Power Save Mode:"Auto SMPS (0)"
    RoamAggressiveness:Roaming Aggressiveness:"3. Medium (2)"
    RoamingPreferredBandType:Preferred Band:"1. No Preference (0)"
    ThroughputBoosterEnabled:Throughput Booster:"Disabled (0)"
    uAPSDSupport:U-APSD support:"Disabled (0)"
    WirelessMode:802.11a/b/g Wireless Mode:"6. Dual Band 802.11a/b/g (34)"
    - "Operating System"
    .Net Framework Version:"4.0,4.8"
    Boot Device:"\Device\HarddiskVolume1"
    Locale:"Portugal"
    OS Manufacturer:"Microsoft Corporation"
    OS Name:"Microsoft Windows 10 Enterprise"
    Other OS Description:"Not Available"
    Page File:"C:\pagefile.sys"
    Page File Space:"32,00 GB"
    System Directory:"C:\windows\system32"
    Version:"10.0.19044 Build 19044"
    Virtual Memory (Available):"42,40 GB"
    Virtual Memory (Total):"63,73 GB"
    Windows Directory:"C:\windows"
    - "Installed Updates"
    KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
    KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
    KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
    KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
    KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
    KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
    KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
    KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
    KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
    KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
    KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
    KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
    KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
    KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
    KB5003791:"Update [10/6/2021]"
    KB5005699:"Security Update [10/6/2021]"
    KB5011352:"Security Update [3/29/2022]"
    KB5011651:"Update [3/30/2022]"
    KB5012170:"Security Update [8/12/2022]"
    KB5013624:"Update [5/19/2022]"
    KB5014032:"Security Update [5/19/2022]"
    KB5014035:"Update [6/18/2022]"
    KB5014671:"Update [7/18/2022]"
    KB5015895:"Update [8/16/2022]"
    KB5016616:"Security Update [8/30/2022]"
    - "Processor"
    - "11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz"
    Architecture:"x64"
    ATPO:"Not Available"
    Caption:"Intel64 Family 6 Model 141 Stepping 1"
    - "Chipset Name":"11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz"
    Link:"http://www.intel.com/content/www/us/en/search.html?keyword=11th+Gen++Core+i7+11800H+"
    CPU Speed:"2,304 GHz"
    Current Voltage:"7. volts"
    Driver:"Not Available"
    Driver Date:"04/21/2009 12:00"
    Driver Path:"C:\windows\system32\drivers\intelppm.sys"
    Driver Version:"10.0.19041.1865"
    Ext. Family:"Not Available"
    Family:"Intel Core™ i7-2760QM"
    FPO:"Not Available"
    INF:"cpu.inf"
    INF Section:"IntelPPM_Inst.NT"
    Level 1 Cache:"8 x 384 KB"
    Level 2 Cache:"8 x 10240 KB"
    Level 3 Cache:"24 MB"
    Load:"1%"
    Manufacturer:"GenuineIntel"
    Model:"141"
    Name:"11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz"
    Number of Cores:"8"
    Number of Cores Enabled:"8"
    Number of Logical Processors:"16"
    Part Number:"None"
    Processor ID:"BFEBFBFF000806D1"
    Revision:"Not Available"
    Serial Number:"None"
    Service Name:"intelppm"
    Status:"OK"
    Stepping:"1"
    - "Storage"
    - "KXG6AZNV1T02 TOSHIBA"
    Capablities:"Random Access, Supports Writing"
    Caption:"KXG6AZNV1T02 TOSHIBA"
    Cylinder - Total:"124519"
    Description:"Disk drive"
    Error Code:"Device is working properly"
    Firmware Revision:"5108AGLA"
    Heads - Total:"255"
    Index:"0"
    INF:"disk.inf"
    Interface Type:"SCSI"
    Manufacturer:"(Standard disk drives)"
    Model:"KXG6AZNV1T02 TOSHIBA"
    Partitions:"3"
    Physical Sector Size:"4096"
    PNP Device ID:"SCSI\DISK&VEN_NVME&PROD_KXG6AZNV1T02_TOS\5&27092EAC&0&000000"
    Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
    SCSI Bus:"0"
    SCSI LUN:"0"
    SCSI Port:"0"
    Sectors - Per Track:"63"
    Sectors - Total:"2000397735"
    Serial Number:"8CE3_8E10_0027_186E."
    Size – Available:"671,47 GB"
    Status:"OK"
    Tracks - Per Cylinder:"255"
    Tracks - Total:"31752345"
    - "C:"
    Availability:"Not Available"
    Caption:"C:"
    Compression Method:"Not Compressed"
    Description:"Local Fixed Disk"
    File System:"NTFS"
    Serial Number:"EC281FF5"
    Size – Available:"671,46773147583 GB"
    Volume Dirty:"No"
    ...#SSU#...
Jean_Intel
Hello afonsoguima,
Thanks for the information provided.
I noticed that your system has a discrete graphics card installed on your system. The NVIDIA GeForce GTX 1650 is part of your laptop. Since your system has two hardware pieces dedicated to the graphics processes, you should know that it is up to the manufacturer to decide how they behave and work together. I would recommend contacting your system manufacturer as they have a much better understanding of how both GPUs (Integrated GPU and Discrete GPU) work together. They will provide you with further Troubleshooting.
Jean O.
