22946 Discussions
Third monitor recognized but I can't extend to it.
GRyan
I am finding a lot of similar questions to the one I am asking but none were identical and hence did not resolve my problem.
I have just added a third monitor to my system. It is recognized but I am unable to get a picture on it or extend to it. Actually I am able to extend to it, however one of the other monitors is then de-activated.
My original two monitors were connected via VGA and DVI respectively. I am attempting to connect the third via HDMI.
My system details are as follows:
Windows 10 - 64 bit
Intel (R) Core i5-4670T
Intel (R) HD Graphics 4600 - Driver Version 20.19.15.4624
MSI H81M-E34 Motherboard.
I'm sure there is a simple solution, but it is proving to be a frustrating problem.
Stefan3D
Check out: https://www.intel.com/content/www/us/en/support/graphics-drivers/000005556.html Frequently Asked Questions about 3 Displays Configuration
GRyan
Hi Stefan3D,
Thanks. However I have been through that list and nothing in there corrected the problem that I am having.
GRyan
Thanks, I'll work may through that document and hopefully find a solution.
GRyan
It does seem like I need a DP, which my motherboard does not come with.
Is it easy enough to add a display port?
I'm open to other suggestions at this stage!
Stefan3D
Can you change sth. in BIOS settings?
https://de.msi.com/Motherboard/support/H81M-E34.html# down-bios Support für H81M-E34 | Motherboard
Update H.5 mentions
- Hide item "IGD Multi-Monitor" when "Initiate Graphic Adapter" set to IGD.
GRyan
I changed "Initiate Graphic Adapter" to IGD, but still no change.
Hi grdnryn,
In order to achieve a 3 displays configuration on your graphics controller a DP connection is needed;
The processor is capable of driving a 3 display configuration following the table mentioned above, so at this stage the recommendation is to contact your computer manufacturer in order to get more feedback on setting a similar configuration. You may also consider adding a graphics card to the motherboard.
My apologies for the inconvenience.
Amy C.
GRyan
OK, thats annoying. But thanks for the reply and answer Amy
Sure, you're welcome.
If there is something else I can help you with, please let me know.
Amy C.
