23282 Discussions
Triple display on HD 4200 Dell Venue Pro 11 - Built in, DP(DVI/VGA), HDMI(DVI)
NLand
I'm trying to get two external displays working from the DELL Venue Pro 11 dock. I have a Core i5-4300Y and HP 4200. I'm trying to find the right combination for triple display to work. The dock has a DP and an HDMI connector on it. I've tried both external monitors on DVI and the DP as VGA but in both cases the DP will not become active. I've tried reading through the FAQs and interpreting the charts of supported combinations but I'm confused.
Can someone help point me in the right direction. I really like this new Windows 8 - Core i5 tablet and just want to drive the dual monitors that my desktop used to support. The 10" display is good for some things but not for all the same things as my larger external monitors. Thank you.
-Nyle
Intel(R) HD Graphics 4200
Driver Version: 10.18.10.3496
Operating System: Windows* 8.1 Tablet PC Edition(6.3.9600)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.2
Physical Memory: 8094 MB
Processor: Intel(R) Core(TM) i5-4300Y CPU @ 1.60GHz
Processor Speed: 1596 MHz
Vendor ID: 8086
Device ID: 0A1E
Device Revision: 0B
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4200
Graphics Output Protocol (GOP) Version: 5.0.1034
Current Resolution: 1280 x 1024
* Devices connected to the Graphics Accelerator *
Active Displays: 2
* Built-in Display *
Display Type: Digital
Serial Number: SDC4c48
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 9.45 inches
Vertical Size: 5.12 inches
Supported Modes
1920 x 1080 (59p Hz)
1920 x 1080 (47p Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 4C 83 48 4C 00 00 00 00
17 17 01 04 85 18 0D 78 0A 3A 75 A2 56 4D 9B 27
0E 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 52 35 80 80 70 38 1F 40 20 20
23 00 EF 86 00 00 00 1A A8 2A 80 80 70 38 1F 40
20 20 23 00 EF 86 00 00 00 1A 00 00 00 FE 00 46
56 30 30 44 80 31 30 38 48 4C 0A 20 00 00 00 00
00 03 41 15 28 01 00 00 00 0B 01 0A 20 20 00 94
* Digital Display *
Serial Number: DEL4026
Gamma: 2.4
Connector Type: DisplayPort
Device Type: DisplayPort
Maximum Image Size
Horizontal Size: 14.96 inches
Vertical Size: 11.81 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
800 x 600 (60p Hz)
800 x 600 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 1024 (75p Hz)
1280 x 1024 (60p Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC 26 40 48 41 47 52
0F 12 01 03 80 26 1E 8C EE 1F 35 A4 56 4D 9E 24
12 50 54 A5 4B 00 71 4F 81 80 01 01 01 01 01 01
01 01 01 01 01 01 30 2A 00 98 51 00 2A 40 30 70
13 00 78 2D 11 00 00 1E 00 00 00 FF 00 46 50 31
38 32 38 34 38 52 47 41 48 0A 00 00 00 FC 00 44
45 4C 4C 20 31 39 30 38 46 50 0A 20 00 00 00 FD
00 38 4C 1E 51 0E 00 0A 20 20 20 20 20 20 00 C4
* Other names and brands are the property of their respective owners.
Allan_J_Intel1
Thanks for joining the community.
I am currently researching on this issue. As soon as I can, I will send you a message with my findings. Thank you for your patience and understanding.
Allan.
NLand
Thank you. If you need any additional debugging information, I'd be happy to provide it. This is a fresh install of Windows 8.1 from the factory. I've used both the latest DELL certified driver and the latest driver from Intel's website.I can't get even a single attached DVI monitor to work from the Displayport, with no other external monitors attached.
Currently, I have one DVI monitor working from the HDMI port and another working from the min-HDMI port on the side of the tablet.
I've tried 3 different models of Dell DVI monitors, including a newer 23 inch. All monitors are in working order.
Any help is greatly appreciated.
Allan_J_Intel1
Sorry for the delayed answer, I have been checking with our engineering team and their response was that you will need to address this matter directly through your computer manufacturer, since tablets are very much different from a normal computer or laptop.
Allan.
NLand
Thank you. I appreciate the answer but could you possibly work towards get someone at Intel working with DELL on the issue. Apparently, DELL has no solution for even getting a single monitor to work on the Displayport reliably unless it's a DP monitor. I think they could really use Intel's help. This is making DELL and Intel look poorly, especially when the Venue 11 Pro is being tested across the Country by many agencies/companies.
I have even purchased an Active adapter and have the second revision of the docking station. I still cannot get video to any DVI monitor we have except from the HDMI ports. It really seems like a driver issue at this point.
acroc
It definitely works, maybe not all active adapters are equal? I use 2 startech dp2dvis, one on an a00 dock and the other on an a01. No arguing the A01 works better, but they work on both. You can always use the mini hdmi on the tablet itself, I did that for a while while I found away to get the dp working, I relalise it's not as convenient.
