22660 Discussions
Trying to determine max size of SATA drive supported for chipset
Hello.
I am trying to determine what the max size SATA hard drive is that we can use in our server.
We have a Dell Poweredge 800 server with 4meg RAM, two 80meg SATA hard drives on the motherboard and an Intel E7221 MCH chipset.
Any help would be gratefully appreciated.
Tony
I know there is an old intel (r) server board which has got the chipset e7221.
Probably, a quick look at the tested harddrives list can give some hints.
http://download.intel.com/support/motherboards/server/sb/se7221bk1_thol_rev17.pdf
I can see that the max sata drive that was tested on this board was 500GB.
More info on this board can be obtained from:
http://download.intel.com/support/motherboards/server/sb/se7221bk1tps1.pdf
All the best,
Kind Regards,
Aryan.
