22945 Discussions
UHD 620 and Screen Going Blank
Jeff_TS
My company uses the Posiflex 6015 POS terminal running Windows 10 with a secondary attached customer facing screen which plays advertisements. The software runs in Electron 21.3. The software was build using the latest version of React 18.2. When there is no active movement on the primary screen, the screen will randomly just go blank. Tapping the screen will cause the content to re-display. This does not happen on other POS terminals running the same software. The latest drivers have not fixed the issue. We have resorted to putting a clock with a second ticker on the most important pages to prevent the screen from going blank. Forum posts seem to indicate this is related to the GPU. Please provide a long term fix for this issue.
Carlos_L_Intel
Hello @Jeff_TS,
Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you. Please help me with the following information in order to assist you:
  • Are you using a straight cable into the port or are you using any type of adapter or docking station?
  •  When did the issue start? Were there any recent changes?
  •  Does this only happen on this app?
  •  To get more information from your system, please install the Intel® System Support Utility (Intel® SSU): https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". Click on "Next", save the report and attach it to your response.
Carlos L.
Carlos_L_Intel
Hello @Jeff_TS,
Were you able to check the previous post? Let us know if you still need assistance.
Carlos L.
Jeff_TS
I did, thank you! I've forwarded the request to our technical team. I'll get you a response next week!
Alberto_R_Intel
Jeff_TS, Thank you very much for your response.
Perfect, no problem at all, take your time and once you get the chance, let us know about any updates.
Albert R.
Alberto_R_Intel
Hello Jeff_TS, I just wanted to check if there are any updates on this scenario and if you still need further assistance on this matter?
Albert R.
Andres_Intel
Hello Jeff_TS,
Andres P.
