23541 Discusiones
UHD 750 driver BUG
asabovesobelow
6.242 Vistas
I've had a long conversation with intel support on facebook now i post it here.
I'm using intel i5-11500 cpu, detailed info in the SSU and GCC.
I found bug in drivers.
In driver version - 27.20.100.9466.
I have stutters and freezes in CS GO, but in DOTA 2 everything seems fine. CPU fequency is normal.
In driver version - 30.0.100.9667 BETA
Stutters and feeezes in CS GO are gone, but in DOTA 2 strange thing happening to CPU frequency it lowers to default CPU clock - 2700Mhz. Same happening in CS GO but it lowers to 3800+ MHz sometimes. But overall it's on maximum.
How can GPU driver affect CPU freq?
Although if you go to windows control panel and turn performance to max CPU frequency normalizes in both games.
I've tried clean installation, etc. It doesn't help
Here's detailed look of the problem:
https://www.youtube.com/watch?v=2sED1FAwQXQ&ab_channel=Denis
0 kudos
10 Respuestas
asabovesobelow
6.216 Vistas
In new driver 9684 it is not fixed. DOTA still working only on STOCK CPU freq
guntrixe
Novato
6.200 Vistas
I have the same problem!
asabovesobelow
6.186 Vistas
How tf can GPU driver affect CPU frequency? this is next level bugs right there
guntrixe
Novato
6.168 Vistas
Bump
asabovesobelow
6.128 Vistas
Can someone get attention to this?
asabovesobelow
6.074 Vistas
up
asabovesobelow
6.025 Vistas
Mr. Galsinger give a slap to devs, thanks
asabovesobelow
5.928 Vistas
Driver 100.9805 still not fixed. I mean come on... This is serious performance problem. Why it's not being fixed
asabovesobelow
5.849 Vistas
30.0.100.9864 nothing is fixed
asabovesobelow
5.834 Vistas
Maybe it's not even bug, but some energo eficienty feature. But why it works on DESKTOP PC? I don't use notebook or something where this feature would be useful. This is shouldn't work like that. Can some dev answer what is this?
Responder
