My main workstation is an ASUS Proart z490-Creator running Windows 11 24H2 and contains an Intel UHD 630 Graphics chip.
I built this workstation clean in Feb 2025 and during the build (following the usual recommended installation advice) - STARTED with the ASUS (Intel) driver for this motherboard - directly from their website.
That specific driver cannot and will not be recognized or will it install at all to Windows 11 24H2. Even tho - right on the ASUS support site for this motherboard - it clearly states this driver IS supported under Windows 11. It does not specifically state that this OEM driver works under 24H2 - and I can confirm it does not.
So I moved to the Intel UHD 630 package and driver v31.0.101.2134 (dated 11/20/2024) installed without a hitch. That is where I am at right now.
That said - I have had several instances of blue screen in Win 11 24H2 in the preceding months - almost always graphics related - so I want to update the Intel Driver to the most current.
So I downloaded the latest 32.0.101.6881 (WHQL Certified) driver from here:
Intel® Arc™ & Iris® Xe Graphics - Windows*
This driver is listed as being 100% compliant with Windows 11 24H2 and 100% supported under my Intel i5 13600K (UHD 630 Graphics).
I fire up the package and after a moment or two - immediately get this:
When I examine the Error Log - I see this - right at the very end of the log:
Basically saying - no driver file in here and no devices are supported?
What is going on? Does this package (just about 6 months newer than the one I already have installed) suddenly not support the UHD 630 - even as it is clearly listed as supporting it?
Looking for some solutions as I see this error is out there - a lot.
Thanks!
B
- Tags:
- driver installation
Hi BMC4930,
- When did the issue start?
- Where did you download the driver?
- What are the troubleshooting steps that you tried so far?
- Have you used DDU to completely remove all residual drivers and installed a new one?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
In line with this, have you tried checking Exit Code 8: "No driver was found that can be installed on the...
Archie D.
Hello BMC4930,
Von M.
Hi BMC4930,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Archie D.
