23660 Discussions
UHD Graphics 630 brightness not working
Amir_96
Good morning,
suddenly my computer's brightness stopped working, I had windows 10 I tried to uninstall the drivers with the guru3d driver uninstaller tool and do a fresh install but it didn't work.
I tried using the standard Windows driver but the ability to manage the brightness disappears from settings.
I updated the Bios at the last version and installed Windows 11, I installed the new drivers but the problem is still present.
My setup:
CPU Intel® Core™ i7-10700 8 core (2,9 GHz) 16 MB cache
Motherboard ASUS® H410T: (Mini-ITX, DDR4, USB 3.2, 6 Gb/s)
Driver from ASUS web site:
Intel VGA driver V30.0.100.9864 For Windows 11 64-bit.
Versione 30.0.100.9864
552.31 MB
2021/10/22
I tried also the Intel Driver & Support Assistant Tool without success.
Can you help me to resolve my issue?
Thank You
Best Regards
Amir_96
thanks everyone, speaking with the computer builder I discovered it was a BIOS parameter:
BIOS -> Advanced -> LVDS Configuration -> Was set to "no" and should be set to 1920x1080 LVDS1
Probably the BIOS default values ​​were restored and having also done the update the manufacturer's custom parameters were lost.
Best Regards
Caguicla_Intel
Hi Amir_96,
Could you please elaborate on the problem you're encountering? Is the issue that you're unable to modify your system's brightness using the slider in the Display settings, or is the brightness slider missing altogether?
Additionally, does your system have a dedicated keyboard shortcut for brightness control, and if so, have you attempted to use it?
Caguicla C.
LeonWaksman
Hi Amir,
The latest graphics driver for your CPU is  Intel® Graphics Driver 31.0.101.2128.  Also in Asus site, for you board (H410T) I can see an outdated driver Version 23.20.16.4849.  Any way, download and install the latest driver from Intel site.
Leon
Amir_96
Best Regards
Caguicla_Intel
Hi Amir_96,
Thank you for sharing the solution to your issue. It's sure to be beneficial for others encountering a similar problem.
We'll proceed to close this discussion. Should you require assistance in the future, please feel free to post a new question, as this thread will no longer be monitored.
Caguicla C.
