23814 Discussions
UHD Graphics 770: different resolution
Sandra78
Hello!
I have a visual impairment and have been using a lower resolution than the native resolution. There was an update for the graphics card, and since then I haven't been able to use any resolution other than the native resolution of 2560 × 1440. Even when I set GPU scaling to “Stretch” mode in the Intel Graphics software, the image gets smaller at lower resolutions. It’s like displaying a 17-inch image on a 27-inch monitor.
I’m now using the native resolution with 180% scaling and increased text size. The problem is that not everything is scaled uniformly. Some text or icons remain so small that it is difficult for me to read them.
I’ve already uninstalled and reinstalled the Intel driver. It didn’t help.
Unfortunately, the Windows Magnifier isn’t useful for magnifying.
I haven't changed anything regarding the hardware.
Does anyone have a recommendation on how I can get the graphics card to implement stretched mode again?
Thank you for your support in advance!
Hardware:
Processor 12th Gen Intel(R) Core(TM) i7-12700K (3.60 GHz)
RAM 32.0 GB (31.8 GB available)
Graphics Card Intel(R) UHD Graphics 770 (128 MB)
Storage 1.44 TB of 3.64 TB used
System Type 64-bit operating system, x64-based processor
Edition Windows 11 Pro
Version 25H2
Monitor LG Ultragear 27"
BuenoS_Intel
Hello Sandra78,
Thank you for contacting us and thank you for providing detailed information about the issue you are experiencing with your Intel® UHD Graphics 770. I understand how important proper display scaling is, especially for accessibility and readability, and I appreciate the troubleshooting steps you have already performed.
To help me investigate this issue further and determine the appropriate next steps, could you please provide clarification on the following points:
  1. What resolution were you previously using before the issue started occurring?
  2. Where did you obtain the graphics driver update (for example: Intel website, Windows Update, Intel® Driver & Support Assistant, or your system/motherboard manufacturer)?
  3. Have you tried using Download Display Driver Uninstaller (DDU) to completely remove the graphics driver before reinstalling it?
  4. Have you checked for and installed the latest Windows updates available for your system?
  5. Could you please provide:
    • Screenshots showing the current display behavior when using a lower resolution with “Stretch” scaling enabled
    • A screenshot of the Intel® Graphics Software scaling settings
    • An Intel System Support Utility (SSU) report for your system
Once I receive this information, I will continue investigating the issue and work with you toward a solution that restores the expected stretched scaling behavior.
Thank you for your cooperation, and I look forward to your response.
Bueno S.
Sandra78
Hi Bueno,
thank you vrey much for your reply!
  1. The resolution was 1366 * 768.
  2. It was the Intel Driver and Support assistant.
  3. No I haven’t. I just learned by your information, that this tool exists.
  4. All Updates are installed.
  5. Regarding the screenshots, I made them in german language as I live in Germany. HEre are the translations:
Scaling Mode: GPU Scaling
Scaling Method: Stretch
Variable Refresh Rate Mode: Not available
Are these the screenshots you need?
ind regards
Sandra
BuenoS_Intel
Hi Sandra78,
Thank you very much for your prompt response and for providing the translated information from the screenshots.
Could you please install graphics driver version 32.0.101.7085 and check whether the issue still persists afterward? Additionally, may I ask if the issue also occurs when using BIOS version F17a for your motherboard? If you require further assistance with the BIOS update procedure, I highly recommend contacting Gigabyte Support, as they can provide guidance specific to your motherboard model.
Once you have had the opportunity to test both, please let me know the results.
Thank you again for your cooperation, and I look forward to your update.
Bueno S.
Sandra78
Hi Bueno,
I installed the suggest driver witout using DDU. But a different resolution still looks like you can see in the attachment.
I have never updated a Bios. I don't know how to do that and risky that is.  And why should I do that anyhow? Everthing was fine a short while ago. Every change I make in the system brings a risk, that the system doesn't work anymore so I can easily use it. I have no one to repair my computer if an update of the Bios fails.
Kind regards
Sandra
BuenoS_Intel
Hi Sandra78,
Thank you for your continued cooperation.
To ensure your information is handled securely and to gather the additional details required for the next steps, I will be sending you a separate private email shortly. This will allow us to continue the discussion and request any necessary information in a more secure manner.
Please keep an eye on your inbox (and spam/junk folder, just in case). Once you receive the email, kindly respond at your convenience so we can proceed without delay.
Thank you for your patience and understanding.
Bueno S.
Sandra78
Hi Bueno,
thank you for your support! I received an email from Shemie B.
Kind regards
Sandra
