23766 Discussions
Ultra-wide Display Resolution Issue
I have reached out to support a few days ago but they have not yet provided a solution for the following issue. I was hoping that if someone may have had the same or very similar issue that they could assist me.
I have a MSI GS60 2QE or model number MS16H5 it has an Intel HD Graphics 5600 details are posted below context
I have connected 2 LG 25UM57 LED-lit Monitors with resolution of 2560x1080, they each have only 2 HDMI inputs
I have one connected to my machine via HDMI Straight Through to HDMI on my machine which out puts a resolution of 2560x1080 lets call this one Monitor A
The second is connected to my machine via HDMI from monitor to a 4K supported HDMI to MiniDP adapter (Staples brand) connected to my machine in the MiniDP which will only give me a resolution of 1920x1080 stretched across the monitor. We will call this one Monitor B
I have swapped connections with Monitor A and the problem follows the MiniDP connection as the HDMI always outputs 2560x1080 to both monitors, all HDMI cables in question have been tested and provide a resolution of 2560x1080.
I can create a custom resolution in Intel HD Graphics Control Panel however when I do this I can only get 44hz refresh rate before the application says it exceeds the bandwidth. I have created the 2560x1080 Custom Resolution with refresh rate of 44z this still causes further complications the monitor (B) displays "Out of Range"
I am looking for solution or workaround for the Intel HD Graphics Control Panel Application as the physical layer has been proven to provide the proper resolution.
I have the most up to date driver which should be noted in the attached files
CommunityAdmin
Thank you for the reports.
I have noticed you are currently using driver version 4568, this driver seems to be customized.
The latest graphics drivers provided by Intel are version 4539.
I would recommend testing driver version https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=87716 4539. Now, if after testing the driver your computer still not able to get 2560x1080 with monitor B, this would be an issue with the video cable (adapter).
Allan.
I would like to know if you were able to test driver version 4539.
Allan.
