23833 Discussions
Unable to install intel graphics driver
I have a Toshiba HP Envy dv6 notebook. It came installed with windows 8 but I downgraded to Windows 7 ultimate 64bit. I have been installing the correct drivers. I am stuck at the graphics drivers. My computer has Nvidia GEFORCE GT 650M. When I try to install the driver for this, it tells me I need to install the intel driver. So, I try to install Intel graphics HD Driver but then it tells me "This computer does not meet the minimum requirements to install this software". I have Intel(R) Core(TM) i7-3630 QM CPU @ 2.40 Ghz. I tried the following driver:
Download Center
which gave me the error I mentioned earlier. Which driver should I be downloading?
BTW, this is what my device manager looks like right now:
http://imgur.com/38lciyc imgur: the simple image sharer
Kevin_M_Intel
Hi oceanus99,
The message you are getting may be caused by an internal configuration on your system. Due to this, I recommend you installing the latest graphics driver for your controller that can be downloaded at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers
In the case you are still getting the message, you can try with the Driver Manual Installation. Here you have the information about this process:
http://www.intel.com/support/graphics/sb/CS-033915.htm http://www.intel.com/support/graphics/sb/CS-033915.htm
