23269 Discussions
Unable to install latest Intel ARC drivers
Jerrod
I'm unable to update my A770 drivers beyond 31.0.101.5085.
Updating from within ARC control center did not work so I uninstalled the drivers using DDU while in safe mode. Installing any driver newer then version 5085 frow within safe  mode does not work, only drivers without ARC control does not work either.
Installing 31.0.101.5085 works fine.
Anything bar full resinstalling windows that I can still try?
Jerrod
I found the problem, and the solution obviously.
Apparantly for some reason 'C:\Program Files\Intel\Media' is read only for me, removing the read only tag fixed the issues.
If anyone can explain why this file became read only that would be cool though.
LeonWaksman
It is not clear to me what method did you used to install the latest Graphics Driver?   Did you executed the .exe file? If not try it.
BTW, the easiest method to repair Windows installation is to perform an in place upgrade. The Windows is replaced without affecting your data and programs.
Leon
Jerrod
I tried both from within arc control and downloading the latest driver and executing the .exe files, same result
Jerrod
Hello again,
I have taken the following steps
Updated motherboard BIOS
Performed in place upgrade to repair my Windows installation
Fully updated Windows installation.
Updated Intel chipset drivers
Updated Intel serial IO drivers
Updated Intel ME drivers
Restarted into Windows safe mode
Uninstalled Graphics Driver using latest version of DDU
Tried to install the latest Graphics Driver using the .exe from the provided link
I get the error as shown in the attachment.
Also included the generated log
Installing driver 31.0.101.5085/31.0.101.5122 (WHQL Certified) works fine
Anything newer does not work.
What am I missing that I can't go beyond driver 5085?
Jerrod
