22843 Discussions
Unable to use 1920x1200 resolution for monitor connected to Thunderbolt dock
tym
I have a problem with setting up resolution (1920x1200) for monitor connected to Thunderbolt dock using DVI-DP cable. The same problem is with passive and active cable. Max available resolution in Windows is 1680x1050.
My PC is equipped with i7-1365U CPU (Dell Latitude 7440) with Iris Xe GPU and I'm using Dell WD19TB dock connected using Thunderbolt.
The problem is visible only in Windows. During boot I have 1920x1200 resolution.
After connect monitor directly to the PC the problem does not occur.
Vivek_Intel
Hi @tym  Please share system specifications that you can collect using Intel System Support Utility .
Can you also check issue with different monitor model to rule out monitor/port/cabel issue?
Vivek_Intel
Hi @tym
Did you get a chance to check above steps ?
Vivek_Intel
Closing this thread.
