23586 Discussions
Undifined behavior. Please update your graphics driver
DuyDinhHoang
I'm using a Dell laptop with i5 1035G1, 2x4GB RAM 2667MHz, MX230 2GB
I just updated the newest driver available right now from Intel (not from Dell)
Someone help me pls
AlHill
You should be using the drivers provided by Dell.
[Windows 11 is the new Vista]
DuyDinhHoang
Yeah. I did use Dell's driver before, but it still didn't work. So I updated the driver with Intel's driver, but it didn't work as well.
AlHill
Dell supposedly tested your laptop with their driver.  If it does not work with their driver, you should be getting support from Dell.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
DuyDinhHoang
This is my result from SSU
DeividA_Intel
Hello DuyDinhHoang,
In order to better assist you, please try the following:
1. Try with the latest Intel driver 30.0.100.9684:
- https://downloadcenter.intel.com/download/30579/Intel-Graphics-Windows-DCH-Drivers
2. Try to disable any antivirus and/or disconnect from the VPN.
3. Try to uninstall and reinstall the Intel® Graphics Command Center (Intel® GCC). Look first at the Microsoft store before uninstalling it.
Deivid A.
DuyDinhHoang
Thank you for your help. But when I try to record the video using Intel GCC before working around it, I realize that GCC has started recording!
At First, I didn't know how, but then I realize that I had just update intel GCC before getting your answer 😃🤣🤣
Seems that my problem has been fixed by updating intel GCC from Microsoft Store.
Thank you again. Have a great day
DeividA_Intel
Hello DuyDinhHoang,
Thanks for the update.
I am glad to hear that you were able to fix the issue by updating the Intel® Graphics Command Center (Intel® GCC) and that now it is working as expected.
I will proceed to close this thread, but if you need further assistance with our products do not hesitate to open a new thread.
Deivid A.
