22925 Discussions
Uninstall definitely Esrv_svc_queencreek
Till3
How can I definately uninstall the annoying "energy server service queencreek ", window  popping up every few minutes?
Thanks for your fast reply.
Edgar
Jose_Intel
Hello @Till3
Thank you for posting on the Intel️® communities.
Is your system up to date now? Energy Server Service queencreek is a service installed by Intel Driver Update Utility. In case you have the latest Intel drivers, you can disable or uninstall this service.
a.    Go to the Device Manager
b.    Look for Intel Driver Update Utilityright-click and select Uninstall.
Jose B.
c9637
Hi Jose,
I found this error in Event Viewer as "Event ID 2 USER_ESRV_SVC_QUEENCREEK" indicating that the installation is corrupted or missing   I do not find Intel Driver Update Utility in Device Manager.
Goto Windows key + x, Apps and Features, search for Intel.  Select Intel Driver & Support Assistant, then Modify.  Then in the Intel popup window select Repair.  Upon completion, a restart will be needed.  Result:  The error went away.  Hope this is useful.
Regards, Charles
Details:
The description for Event ID 2 from source USER_ESRV_SVC_QUEENCREEK cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Error [0]: [Unable To Open A Registry Key.][0x57].
Occurred: [Mon Apr 15 15:13:43 2024].
In file: [driver.c].
At line: [21407].
The specified resource type cannot be found in the image file
Jose_Intel
Hello Till3
We hope you are doing fine.
Jose B.
Jose_Intel
Hello Till3
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
