23769 Discussions
Uninstalling Graphics Control Panel
NLauz
Hello everyone,
A while back I installed the Intel Graphics Command Center from the Windows Store on my Lenovo Yoga C930 laptop. Recently upon opening it it recommends that I uninstall the old Intel Graphics Control Panel. How do I do this? I know uninstalling the graphics driver removes the panel, but that seems silly as I obviously want the latest grpahics driver... Does the Command Center simply come with the latest driver as well?
Thank you,
Noah
LeonWaksman
Hi @NLauz​ ,
  1. The Intel Graphics Command Center (IGCC) was included in Intel DCH Graphics Driver and installed with this driver. In the latest version of this driver (Version: 26.20.100.7463), the Intel Graphics Command Center was not included in the driver package, although according to the Release Notes, attached to driver download page https://downloadmirror.intel.com/29195/eng/ReleaseNotes_100.7463.pdf, it should be included.
  2. I have NUC7i7DNHE, with Intel UHD Graphics 620, similar to your laptop. On this NUC, after updating graphics driver to version 26.20.100.7463, the Intel Graphics Command Center wasn't installed any more. So, I've downloaded it and installed from the Microsoft Store.
  3. I've downloaded from Microsoft Store and installed also the Intel Graphics Control Panel (IGCP).
  4. I'm using both applications: IGCP and IGCC. Both can work side by side. There are not redundant, since not all functions existing in IGCP are available in IGCC.
  5. So, while running IGCC, disregard the advice and check "Do not show again".
Leon
AlHill
Start, settings, apps, apps & features, select the Intel GCP, uninstall.
Doc
NLauz
Hello Doc,
Thank you for such a quick reply but I don't seem to have that as a standalone application, which is why I was confused in the first place.
Noah
AlHill
What is your processor model number?
What version of windows 10? 1903? 1909?
What is the version of your graphics driver?
Do you have dual graphics?
Are you using the drivers provided by Lenovo?
Doc
NLauz
Hi Doc,
My processor is a i7-8550U.
I am running Windows 10 version 1909.
My graphics driver is version 26.20.100.7463.
No, I only have integrated graphics.
And yes I use the Intel Driver Support Assistant which detects my machine's model and provides the appropriate drivers.
Thank you,
Noah
AlHill
Well, because this is a lenovo laptop, you should be using the graphics (and other) drivers provided by them.
Download, run, and attach (using the paperclip) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Doc
NLauz
Doc,
I thought the drivers I use are tied to my machine specifically and therefore should be identical to what's on Lenovo's site, but I've attached the text file of results.
Thank you so much for all the help,
Noah
AlHill
No, they are not identical. And, lenovo may be whitelisting/blacklisting drivers.
Doc
NLauz
Doc,
Good to know! Thank you so much.
I used Lenovo's own utility to see if a different driver was available, but didn't get anything. So I guess I'll wait and see if an Intel support engineer can help.
Thank you again,
Noah
LeonWaksman
Hi @NLauz​ ,
Leon
NLauz
Hi Leon,
That's interesting because my driver seems to include the desktop HD Graphics Control Panel, as I had to install the Command Center from the Windows Store myself (and it's never been uninstalled). I know they run together just fine so I guess I'll take your advise and hide it like I did before. I was just curious if I could uninstall the HD Panel like it was recommending.
Thank you,
Noah
