23538 Discussions
Updated Intel Q45/Q43 Express Chips Drivers for Windows 10
CCarl6
Hey guys got a question for you guys.
So my OS is windows 10 64 bit,computer Optiplex 960.Im trying to play a game Called Minecraft.Welp im having a bad drivers error.
Btw i have two Intel Q45/Q43 Express Chipset
I cant even find the drivers for my graphics card please help.
Heres some extra info:
Manufacturer Intel
Model Q45/Q43 Express Chipset
Device ID 8086-2E12
Revision 4
Subvendor Dell (1028)
Current Performance Level Level 0
Driver version 8.15.10.2702
Count of performance levels : 1
Level 1 - "Perf Level 0"
Manufacturer Intel
Device ID 8086-2E13
Revision 4
AlHill
The Q45/Q43 is not supported on Windows 10. Look way down this page under "legacy":
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products
However, you can try the Windows 10 driver here:
http://www.catalog.update.microsoft.com/Search.aspx?q=intel%20q45%20windows%2010 Microsoft Update Catalog
Doc
AlHill
Doc
JH_Gamerzz
how to use the chipset to apply it
Hello CarlLeo,
Al_Hill is right. The supported operating systems for your chipset are;
  • Windows 2000
  • Windows XP
  • Windows Vista
  • Windows 7
  • Windows 8
From our end there are no drivers for older platforms and Windows® 10, my recommendation is to try the suggestion mentioned above or you can always rollback to one of the operating systems for driver availability.
Check the link provided above for more reference on the supported operating systems.
Amy.
CCarl6
Hey could you guys send me a link to the The WDDM 1.0 Vista drivers. I heard it works Perfectly with Windows 10.
Hey is this a legitimate website. Is it safe to download from?
AlHill
Is this a legitimate website? Yes, both Intel.com and Microsoft.com are legitimate websites.
Is it safe to download from? Yes, it is safe (safe being a relative term) to download from Intel and Microsoft sites.
The question "Is it safe?" reminds me of Laurence Olivier in the movie "Marathon Man":
You can find all the drivers you want for your chipset at the link I provided (which is a Microsoft site):
http://www.catalog.update.microsoft.com/Search.aspx%3Fq%3Dintel%2520q45%2520windows%252010 Microsoft Update Catalog
You should note that the Windows Vista driver is unlikely to work with Windows 10, despite what you have heard. That is why there are different drivers for different versions of Windows. You are welcome, however, to download and try whatever you want. You can select what you want merely by visiting the link I provided.
Remember, your chipset is NOT supported on Windows 10.
Doc
CCarl6
MSchu27
Nice to hear this
Do you know that Microsoft updated many Windows7/8 systems to Windows 10? And all this people are very happy
And further your tool http://downloadmirror.intel.com/24345/a08/Intel%20Driver%20Update%20Utility%20Installer.exe Intel Driver Update Utility (version 2.6.2.4) crashed by installing "Intel Chipsatz-Gerätesoftware (INF-Update-Utility-EXE nur)" (version 10.1.1.14, date 2016-02-14) .
[code]
[1CA4:1F6C][2017-02-15T19:09:08]i001: Burn v3.7.1224.0, Windows v6.2 (Build 9200: Service Pack 0), path: C:\Users\xxxx\Downloads\Intel Components\SetupChipset.exe, cmdline: '-burn.unelevated BurnPipe.{EAEFEC83-8813-4D0B-889D-9ED8BC9DD5E1} {DC774B05-FB4E-4A8C-8C90-B3EF1FDCB9B2} 5816'
[1CA4:1F6C][2017-02-15T19:09:08]i000: Initializing string variable 'IIF_ProductVersion' to value '10.1.1.14'
[1CA4:1F6C][2017-02-15T19:09:08]i000: Initializing string variable 'IIF_InstallerVersion' to value '3.1.6'
[1CA4:1F6C][2017-02-15T19:09:08]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx86.msi' to value ';NullDrivers.cab;NOT VersionNT64'
[1CA4:1F6C][2017-02-15T19:09:08]i000: Initializing string variable 'IIF_ExtractionMapping_SetupChipsetx64.msi' to value ';NullDrivers.cab;VersionNT64'
[1CA4:1F6C][2017-02-15T19:09:10]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\xxxx\AppData\Local\Temp\Intel\Logs\Chipset_20170215190910.log'
[1CA4:1F6C][2017-02-15T19:09:10]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\xxxx\Downloads\Intel Components\SetupChipset.exe'
[1CA4:1F6C][2017-02-15T19:09:10]i052: Condition 'VersionNT >= v6.1 OR (VersionNT = v6.0 AND NTProductType = 3)' evaluates to true.
[1CA4:1F6C][2017-02-15T19:09:10]i000: Setting string variable 'WixBundleName' to value 'Intel(R) Chipset Device Software'
[1CA4:1F6C][2017-02-15T19:09:10]i000: Loading managed bootstrapper application.
[1CA4:1F6C][2017-02-15T19:09:10]i000: Creating BA thread to run asynchronously.
[1CA4:17EC][2017-02-15T19:09:10]i000: ** MBA ** Command line:
[1CA4:17EC][2017-02-15T19:09:11]i000: Setting string variable 'WixBundleName' to value 'Intel® Chipsatz-Gerätesoftware'
[1CA4:17EC][2017-02-15T19:09:11]i000: ** MBA ** Calling Engine.Detect()
[1CA4:1F6C][2017-02-15T19:09:11]i100: Detect begin, 3 packages
[1CA4:1F6C][2017-02-15T19:09:11]i000: Setting string variable 'DotNet35' to value '1'
[1CA4:1F6C][2017-02-15T19:09:11]i000: Setting string variable 'DotNet40Client' to value '1'
[1CA4:1F6C][2017-02-15T19:09:11]i000: Setting string variable 'DotNet40Full' to value '1'
[1CA4:1F6C][2017-02-15T19:09:11]i000: Setting string variable 'DotNet45' to value '394802'
[1CA4:1F6C][2017-02-15T19:09:11]i052: Condition 'DotNet35 OR DotNet40Client OR DotNet40Full OR (DotNet45 >= 378389)' evaluates to true.
[1CA4:1F6C][2017-02-15T19:09:11]i101: Detected package: DotNet45, state: Present, cached: None
[1CA4:1F6C][2017-02-15T19:09:11]i101: Detected package: SetupChipsetx86.msi, state: Absent, cached: None
[1CA4:1F6C][2017-02-15T19:09:11]i104: Detected package: SetupChipsetx86.msi, feature: NullDriverFeature, state: Absent
[1CA4:1F6C][2017-02-15T19:09:11]i104: Detected package: SetupChipsetx86.msi, feature: PackageVersionFeature, state: Absent
[1CA4:1F6C][2017-02-15T19:09:11]i104: Detected package: SetupChipsetx86.msi, feature: LicenseAgreementFeature, state: Absent
[1CA4:1F6C][2017-02-15T19:09:11]i101: Detected package: SetupChipsetx64.msi, state: Absent, cached: None
[1CA4:1F6C][2017-02-15T19:09:11]i104: Detected package: SetupChipsetx64.msi, feature: NullDriverFeature, state: Absent
[1CA4:1F6C][2017-02-15T19:09:11]i104: Detected package: SetupChipsetx64.msi, feature: PackageVersionFeature, state: Absent
[1CA4:1F6C][2017-02-15T19:09:11]i104: Detected package: SetupChipsetx64.msi, feature: LicenseAgreementFeature, state: Absent
[1CA4:1F6C][2017-02-15T19:09:11]i199: Detect complete, result: 0x0
[1CA4:1F6C][2017-02-15T19:09:29]i200: Plan begin, 3 packages, action: Install
[1CA4:1F6C][2017-02-15T19:09:29]w321: Skipping dependency registration on package with no dependency providers: DotNet45
[1CA4:1F6C][2017-02-15T19:09:29]i052: Condition 'NOT VersionNT64' evaluates to false.
[1CA4:1F6C][2017-02-15T19:09:29]i204: Plan 3 msi features for package: SetupChipsetx86.msi
[1CA4:1F6C][2017-02-15T19:09:29]i203: Planned feature: NullDriverFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[1CA4:1F6C][2017-02-15T19:09:29]i203: Planned feature: PackageVersionFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[1CA4:1F6C][2017-02-15T19:09:29]i203: Planned feature: LicenseAgreementFeature, state: Absent, default requested: Unknown, ba requested: Unknown, execute action: None, rollback action: None
[1CA4:1F6C][2017-02-15T19:09:29]i052: Condition 'VersionNT64' evaluates to true.
[1CA4:1F6C][2017-02-15T19:09:29]i204: Plan 3 msi features for package: SetupChipsetx64.msi
[1CA4:1F6C][2017-02-15T19:09:29]i000: Setting string variable 'WixBundleRollbackLog_SetupChipsetx64.msi' to value 'C:\Users\xxxx\AppData\Local\Temp\Intel\Logs\Chipset_20170215190910_0_SetupChipsetx64.msi_rollback.log'
[1CA4:1F6C][2017-02-15T19:09:29]i000: Setting string variable 'WixBundleLog_SetupChipsetx64.msi' to value 'C:\Users\xxxx\AppData\Local\Temp\Intel\Logs\Chipset_20170215190910_0_SetupChipsetx64.msi.log'
[1CA4:1F6C][2017-02-15T19:09:29]i201: Planned package: DotNet45, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1CA4:1F6C][2017-02-15T19:09:29]i201: Planned package: SetupChipsetx86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[1CA4:1F6C][2017-02-15T19:09:29]i201: Planned package: SetupChipsetx64.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[1CA4:1F6C][2017-02-15T19:09:29]i299: Plan complete, result: 0x0
[1CA4:17EC][2017-02-15T19:09:29]i000: Setting string variable 'IIF_MSI_SWITCHES' to value ''
[1CA4:17EC][2017-02-15T19:09:29]i000: ** MBA ** Getting window handle.
[1CA4:17EC][2017-02-15T19:09:29]i000: ** MBA ** Calling Engine.Apply(). Window handle: 264442
[1CA4:1F6C][2017-02-15T19:09:29]i300: Apply begin
[16B8:2114][2017-02-15T19:09:2...
grenadi, try the manual installation for this driver. Find it here; https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility- Download Intel® Chipset Device Software (INF Update Utility)
Amy.
AlHill
Seriously, this is a 6-year old thread.   And, the Q45/Q43 is not supported on Windows 10.
