22737 Discussions
V-Ray fails to compile for Intel HD 4400 and probably any iGPU due to common runtime.
UUSRD
Reading the V-Ray output log it is clear it fails to compile the raytracer for Intel HD 4400 OpenCL runtime. It doesn't matter the scene's complexity it happens always.
Qt: Untested Windows version 6.2 detected!
Successfully initialized spawner. Waiting for jobs...
Received TM_START_RENDER from 127.0.0.1
Starting DR session from 127.0.0.1
Receiving DR scene from 127.0.0.1
[DR] getting sequence data...
[DR] Calling beginSeqeunce()
Preparing renderer...
Preparing scene for rendering...
OpenCL renderer requested.
loadLibrary(C:\ProgramData\ASGVIS\Common\x64\vc10\Distributed Rendering\rt_opencl.dll)
Found plugin "RTOpenCL"
Plugin library "C:\ProgramData\ASGVIS\Common\x64\vc10\Distributed Rendering\rt_opencl.dll" loaded.
1 plugin(s) loaded successfully
OpenCL renderer plugin successfully loaded from "C:\ProgramData\ASGVIS\Common\x64\vc10\Distributed Rendering\rt_opencl.dll"
OpenCL renderer plugin instance successfully created.
EXT_RTOPENCL interface obtained successfully from OpenCL renderer plugin instance.
[DR] getting frame data...
[DR] frame number is 0
[DR] Calling beginFrame()
Preparing camera sampler.
Preparing scene for frame...
Compiling geometry...
Preparing ray server.
Building SDTree for GPU
Scene is empty.
Preparing direct light manager.
Preparing global light manager.
[DR] Calling renderImage()
Running RTEngine
Initializing OpenCL renderer (single kernel version)...
Querying for OpenCL devices...
Environment variable VRAY_OPENCL_PLATFORMS_x64 not found - using all available devices
Found 2 OpenCL platforms
Using the following OpenCL devices:
Intel(R) OpenCL Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz
Intel(R) OpenCL Intel(R) HD Graphics 4400
NVIDIA CUDA GeForce GT 750M
CPU TUPLE SIZE = 2
Using memory buffers for textures
Using global ray states
cl_nv_compiler_options extension not found.
Building OpenCL trace program for device Intel(R) OpenCL_Intel(R) HD Graphics 4400...
Error Program build failure (-11) at line 1467 , in file ./src/opencl_main.cpp !!!
Failed to compile OpenCL kernels, falling back to CPU code.
buildProgram() failed for device 0
initDevices() failed.
Number of lights: 0
Number of area lights: 0
Number of moving area lights: 0
Total number of lights added by updateLights(): 0
Setting up 4 thread(s)
Number of raycasts: 0
Camera rays: 0
Shadow rays: 0
GI rays: 0
Reflection rays: 0
Refraction rays: 0
Unshaded rays: 0
Clearing global light manager.
Clearing direct light manager.
Clearing ray server.
Clearing geometry.
Number of intersectable primitives: 0
SD triangles: 0
MB triangles: 0
Static primitives: 0
Moving primitives: 0
Infinite primitives: 0
Clearing camera image sampler.
Clearing camera sampler.
Clearing DMC sampler.
Clearing path sampler.
Clearing color mapper.
Scene constructed in 4.9 seconds
[RenderView] startCameraTime=0.000000, endCameraTime=1.033333
[RenderView] numCameraTMs=62, numFrames=31, frameSamples=2
OpenCL renderer plugin already loaded.
Scene bounding box is [-28.7711,-29.052,3.27523]-[28.1591,30.7112,197.953]
Number of lights: 2
Total number of lights added by updateLights(): 1
Writing crash dump to "C:\Users\(*)\AppData\Local\Temp\VRay.dmp"
Raghupathi_M_Intel
For OpenCL issues and support please post on the OpenCL support forum https://software.intel.com/en-us/forums/intel-opencl-sdk here.
It looks like you are getting build failure. Is there any way you can attach your kernel?
Raghu
Jose_H_Intel1
Would you please provide the http://www.intel.com/support/graphics/sb/cs-009476.htm Intel® HD Graphics report and DxDiag report (Press Windows* key + R key, type "dxdiag", click on "Save All Information…").
Jose_H_Intel1
Thanks, I have reported your issue. I will keep you informed.
Raghupathi_M_Intel
Raghu
