22980 Discussions
Video graphic accidentally disabled, boots up but can only see a black screen. Bios video configuration is set for ext PCIe. Selection Provided: Auto, Int Graphics(IDG),Ext PCIE (Peg), and Ext PCI Graphics. Is select auto or intel graphic good idea
RRobe18
I need to know how to obtain video. bio gives 4 selections, one of which is the one disabled. 907 345-2098 rtkean
Hello rtkean,
If you have an external GPU connected to the PCIe slot, then it is required to connect the video cable (HDMI, DisplayPort, VGA or DVI) to the back of the external GPU.
In case you don't have an external GPU, you can plug the video cable directly to the motherboard, if this is the case, you can select "Auto" or "Int Graphics (IDG)" which should provide vide to you.
Is the case still present after following above instructions? Then please try to use different video ports and cables (HDMI, DisplayPort, VGA or DVI) this is in order to find out what could be triggering the issue (Cables or ports).
Additionally, please provide me with the model of your motherboard/Processor or brand and system model.
Hope I can hear from you.
Esteban C
Hello rtkean,
Esteban C
Hello rtkean,
This is to follow up on your case, do you still require support for the inquiry you had?
Please let me know
Esteban C
Hello rtkean,
Just wanted to double check if you still require support for your inquiry.
Please let me know.
Esteban C
