23078 Discussions
Video playback causes screen flicker after latest Windows update
Bob36
Lenovo Thinkpad
Intel Iris Xe Graphics - Driver Version: 32.0.101.5972
Windows: Windows 11 Pro - 24H2 26100.3194
Screen flickering to black occurs mostly commonly when playing video in browsers (Chrome and Firefox) but happens at other times as well for example just opening a browser of the Lenovo update utilities.
Bob36
It's no longer happening after I updated to the latest intel driver.  I think it was just happening on the laptop screen.
RandyT_Intel
Hi Bob36,
Please try the following recommendations below on How to Fix a Flickering Screen with Intel® Graphics.
If the flickering started after a change in configuration, software installation, update, etc., undo those changes and check if the issue occurs again. This will help isolate the root cause.
Additional Troubleshooting:
    1. On your IGCC program, click Displays and lower the resolution to the next setting.
    2. Change the refresh rate to a lower setting.
    3. Put the system on full power.
  1. Disable Desktop Window Manager:
      1. Access the Power User menu by right-clicking the Windows taskbar icon.
      2. Select Run.
      3. Type services.msc into the Run dialog box.
      4. Locate Desktop Window Manager Session Manager.
      5. Right-click it and select Stop.
      6. Right-click Desktop Window Manager Session Manager again.
      7. Select Properties.
      8. Under the General tab, modify the start-up type to Disabled.
    1. Press OK.
  • If you do not have access to the Intel Graphics Command Center, you can change the refresh rate to a lower setting using Windows Advance Display Settings
    1. Right-click the desktop screen and select display settings
    2. Scroll down and press on Advance Display Settings
    3. Choose a native built-in display monitor (If laptop)
    4. Under Refresh rate, Change the refresh rate to a lower setting.
    2. Select Run.
  2. Press OK.
Let me know if this works on your end.
Randy T.
RandyT_Intel
Hi Bob36,
I'm following up on the previous recommendation I provided. Have you had a chance to review the information and apply it to your system? Please let me know the outcome so I can determine the next best course of action.
Randy T.
Bob36
The flickering is still happening.  I updated the Lenovo bios, and it stopped for a few days and it started happening again.
RandyT_Intel
Hi Bob36,
Is this issue also occurring when using an external monitor, or does it only happen on the laptop's display? Please try isolating the problem by connecting an external monitor. If the issue does not appear on the external monitor, it suggests a potential conflict with the operating system or the graphics driver installation. In this case, we should perform a clean installation of the graphics driver and obtain the OEM driver from Lenovo to avoid compatibility issues.
Randy T.
Bob36
RandyT_Intel
Hi Bob36,
I'm glad to hear that updating to the latest Intel driver resolved the issue for you! If you encounter any more problems or need further assistance in the future, please don't hesitate to submit a new support ticket. We're here to help with any issues you might face.
Randy T.
