23851 Discussions
Virtual Display Custom Resolution
RM-J
I have a headless computer connected to a realvnc client. The client is not configurable. Once the client connects, I can open display properties and change the resolution of the display. the issue is that for the client display to be fully utilized I need to set a custom resolution on the computer. the Intel driver will not let me set custom resolutions for virtual displays. Is there a way to actually accomplish this?
Hello, angos.
Thank you very much for taking the time to reach the Intel® Communities Team.
I understand you would like to set a custom resolution for a virtual display.
Allow me to share with you that the Intel® HD Graphics properties will only be able to modify the settings of a physical monitor or display, a virtual display is handled by the Operating System. I will highly recommend you to get in touch with the support of your OS in order to change these settings.
Antony S.
