23525 Discussions
Visual Bios 2.2.17 features seem to be missing
Greetings. I am trying to change some of the voltages for the graphics processing unit however it seems that the settings in the BIOS version that I have are much different from any of the tutorials that I have seen online. Also some of the text in the visual bios settings describes features which I see that are not present.
As stated in the photo above there is reference to a diagram, which I clearly cannot see
I have combed over the Internet searching high and low for tutorials or even some kind of documentation on how to use this version of Intel visual bios, but have found no such documents. I am wondering if something is wrong with the version that I have, or if some features have been removed in this version
running Visual Bios 2.2.17 on Intel NUC i7-5557u
Hello, Bluerose555:
Thank you for contacting the Intel Communities.
I would like to gather some information about the scenario you are encountering with.
May I have those tutorials mentioned, to better understand what would you like to achieve with the device?
Also, with that information I could be able to let you know whether or not that is changable or that can be modified.
In regards to the diagram, it is to be seen as a whole, meaning that the different tabs will let you modify what is noted there.
I look forward to hearing from you.
Esteban C
Bluerose555:
I was checking this thread and I would like to know if there is any update regarding the information requested previously.
Esteban C
Hey, Bluerose555:
I would like to double check if you were able to gather up the information requested above in order to further assist you on this inquiry.
Look forward to hearing from you.
Esteban C
Bluerose555:
I was checking this thread and started wondering if you were able to get the BIOS changes as desired.
Look forward to hearing from you 🙂
Esteban C
