23755 Discussions
Vulkan API Issue - vkGetPhysicalDeviceMemoryProperties returns incorrect values
retroNUC
Follow-up on my previous closed issue - Vulkan - BETA Drivers Break RetroArch/ParaLLel-RDP - Intel Community
Worked with the developers as suggested, who identified an issue with the Vulkan API implementatio on Intel Graphics drivers since 27.20.100.9616:
"ParaLLel-RDP crashes on current Intel Xe drivers. On newer drivers vkGetPhysicalDeviceMemoryProperties calls incorrectly populates the VkPhysicalDeviceMemoryProperties struct values meaning that all contained memoryTypes->propertyFlags fields return 1 instead of the or'd flag values."
[Parallel-RDP] Crashes on load for newer Intel Xe drivers - "This device probably does not support 8/16-bit storage" · Issue #383 · libretro/mupen64plus-libretro-nx (github.com)
Fix Parallel-RDP on Intel Xe by stuken · Pull Request #388 · libretro/mupen64plus-libretro-nx (github.com)
Could this be passed along to engineers to potentially investigate the issue? Thank you!
retroNUC
With further debugging from the software developers, it turned out to be a separate issue, so feel free to ignore this. Thanks.
AndrewG_Intel
Hello @retroNUC
We understand that this is a separate issue that you are debugging with the software developer and as per your request, we will ignore this request, therefore, we will proceed to close this thread now.
Andrew G.
