23259 Discussions
[W10 Fall Creators Update x64] Intel HD 4400 Latest Drivers Causing Screen Flickering in Videogames
KGall2
I initially voiced out this issue on a similar thread because me and the OP had the same integrated GPU, but I was advised by Intel themselves to start up a new thread.
Basically what happens is: on Windows 10 x64 Fall Creators Update (ver. 1709), with Intel HD 4400 and the latest drivers (15.40.36.4703), if I run any videogame without an FPS limiter/ingame VSync enabled, the screen will flicker wildly, and disappears if VSync is enabled app-wise (driver-wise hard VSync does not work). I believe this is a compatibility issue with the latest build of Windows 10, mainly because I had the same version on Creators Update and there were no problems.
I tried both with Game Mode and DVR off, but they do not fix the issue...
Attached are the requested diagnostics:
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Screen will flicker if VSync or FPS Limiter is OFF
Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")<p>
Always (100%): X
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):
Hardware (HW)
Brand and Model of the system.
Intel Core i5-4210U @ 1.7 GHz with Intel HD 4400
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?<td style="padding: 0 5.4pt; bo...
Bryce__Intel
We released a driver https://downloadcenter.intel.com/download/28163 15.40.41.5058 and were unable to see the issue with this. Could you update, retest, and let us know if you're still able to see this failing? Thanks.
