23104 Discussions
WIndows 10 build 9879
GPlev
Hi, I'm running build 9879 x64 on a NUC D54250WYK. Pretty smooth - November WIn 8.1 driver bundle installed/worked well, except noticed that WiDi no longer correctly functioned (did not function with MS driver either. Attempted to install gfx_win7_8_8.1_64_15.36.7.3960 graphics bundle, but was stopped by "computer does not minimum requirements..." message. I'm assuming there's an OS version filter now embedded in distro. Is there a force that I can use to attempt to install the updated drivers? (knowing that this is a test machine that I can tear down if it blows up)
Allan_J_Intel1
Thanks for joining the NUC community.
Check the list of supported operating systems for your NUC model: http://www.intel.com/support/motherboards/desktop/sb/CS-034034.htm Intel® NUC — Supported Operating Systems
Allan.
