23691 Discussions
WMI Provider Host issues after installing Intel Graphics Software
cam50
Updated graphics divers to gfx_win_101.6449_1016256 on 01/05/2025 had no issue. Then on 01/09/2025 I was checking task manager after seeing unusual write activity to the SDD and seen WMI Provider Host, Intel Graphics Software, Asus Armoury Crate, and a bunch of Microsoft service hosts constantly using CPU and writing to SSD.
I checked the WMI logs and found errors for Intel Graphics Software, Intel PresentMon API, Intel Extreme Tuning, and Asus Armoury Crate dating back to the 01/05/2025 driver install.
Checked the Windows System logs and found a bunch of warnings and errors related to these same programs.
Everything is working fine other than the CPU and SSD write usage. From what I read in the logs it seems like the there is a conflict involving sensor data and hardware identification. I use Armoury Crate for system fan controls and Intel Graphics Software for fan controls on Sapphire A770 graphics card. HWiNFO64 shows all temperatures and fans are running according to settings.
My main concern is the amount of write to my SSD as it is reaching 100's of gigabytes a day.
Thanks in advance for any attention you give this issue and I am willing to give you any additional information about and from logs.
JeanetteC_Intel
Hello cam50,
I'm currently looking into this issue and would need to know more about your system configuration so I we can fully check and provide you with an accurate fix. This can be shared by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save (.txt)
I will wait for your reply.
JeanetteC.
cam50
Thank you for reply. I have attached the scan from SSU, let me know if you need more logs or information.
Will also make a support post to ASUS as I think the WMI issue might be a conflict between Armoury Crate and the new Intel Graphics software when requesting hardware information and sensor data. WMI logs show both these programs timing out when what looks like they are requesting hardware information or sensor data.
Earl_Intel
Hi cam50,
Thank you for providing the SSU logs, no worries, I will further check on this internally and provide an update on this thread as soon as I can.
Earl E.
JeanetteC_Intel
Hello cam50,
Good day!
Please be advised that in our latest internal tests the issue is resolved after applying the latest Windows updates.
I hope this helps.
JeanetteC.
JeanetteC_Intel
Hello cam50,
Were you able to see my previous post?
Let me know if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello cam50
Good day.
Since the issue was resolved on the latest internal tests, after applying the latest Windows updates, I highly recommend contacting Microsoft Support team for further assistance and to help with the latest windows update that can address the WMI issue.
I'll proceed in closing this case now. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Sinerely,
JeanetteC.
