22849 Discussions
Waiting for a new graphic driver for NUC HVK model
JChoi49
current version of graphic driver is slightly old. Any plan to update the driver?
AlHill
What are you talking about? The latest driver is here and is dated June 19, 2019: https://downloadcenter.intel.com/download/28888/Intel-Graphics-Windows-10-DCH-Drivers?v=t
Doc
AlHill
Also, "old" is a relative term. Define what you think "old" is.
Doc
JChoi49
​Ha, I am talking about AMD GRAPHIC DRIVER for HVK. if you want to answer my question, you should check the spec of HVK first. there are TWO graphics.
AlHill
I know there are two drivers. I have a HVK. My point is you can install the latest DCH driver (if you want). The AMD driver is from feb 14, 2019. With the DCH driver, and AMD driver, you will be completely updated.
So, what is your problem with the driver - just that it is (in your mind) "old", or do you actually have a problem with the graphics?
Doc
Alan_J_T
If like me then out of date is when the one on the AMD site is Newer by a Month or more
Radeon Software
Revision Number
Adrenalin 2019 Edition 19.4.1
File Size
328 MB
Release Date
4/3/2019
But one can also update to this version direct from AMD, I do and it works just dandy
All I do is make sure all Intel Driver are up to date then go to AMD Download there latest drivers Not the Optional ones first time around just in case it dose not work
Run the Install program and select a clean install and I have the latest up to date AMD drivers.
As you can see from picks.
Hope this helps OH yes select AMD Vega 64 Drivers from the AMD site is the ones I use,
Perhaps Intel will let AMD do the drivers one day for the GPU
Alan_J_T
I am just downloading latest version now to Install will be doing the install a bit different though will not do a clean but a upgrade to the new ones, As I have found that doing a clean install on AMD Drivers and not Intel ones some times wont work, as the install may fail.
Okey Dokey That worked well so am now running the version below with no problems found
Radeon Software
Revision Number
Adrenalin 2019 Edition 19.7.1 Optional
File Size
419 MB
Release Date
7/7/2019
Abigail_G_Intel
Hello JChoi49,
Thank you for posting on the Intel Communities.
Your feedback is highly appreciated, I will submit this feedback to our specialists.
Abigail G
Under Contract to Intel Corporation.
