22952 Discussions
Weird graphic game glitch
MMan3
So i'm playing Young Justice Legacy on my laptop It works perfectly, but I notice a small graphic glitch the characters don't appears on the menu instead I sometimes I get a blue screen or a bunch of colors like its messed up or something. I tested it on my desktop and I didn't get this issue and they appeared fine, but in my laptop this glitch happens
,but on my desktop they appear fine
The Graphic Drive I have installed on my laptop is an intel HD Graphic (Core i3) Driver Version 8.15.10.2559 it is the most up to date one at least that what the intel utility update says. I've looked online for a solution, but no luck. This is the only problem I'm having.
Kevin_M_Intel
Hi maskedman,
I am sorry to hear you are having problems but let me help you.
I would like to verify some more information about the system so can you post your graphics report and the dxdiag report here?
How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Copy/Paste here.
Graphics Report: Right click on desktop> Graphics Properties> Options> Drop Down Menu> Information Center> Save> Open .txt file created> Copy/Paste here.
MMan3
Okay Here it is
System Information
Time of this report: 2/26/2014, 01:26:33
Machine name: OWNER-HP
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP Pavilion dv6 Notebook PC
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i3 CPU M 370 @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 3894MB RAM
Page File: 1497MB used, 6288MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
Intel® HD Graphics (Core i3)
Report Date: 2/26/2014
Report Time[hr:mm:ss]: 1:28:46
Driver Version: 8.15.10.2559
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: English (United States)
DirectX* Version: 10.1
Physical Memory: 3893 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 72 MB
Processor: Intel64 Family 6 Model 37 Stepping 5
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0046
Device Revision: 02
* Accelerator Information *
Accelerator in Use: Intel(R) HD Graphics
Video BIOS: 2050.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 13.39 inches
Vertical: 07.48 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C A3 51 41 00 00 00 00
00 12 01 03 80 22 13 78 0A 87 F5 94 57 4F 8C 27
27 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 12 1B 56 72 50 00 0C 30 30 20
25 00 58 C2 10 00 00 19 00 00 00 0F 00 00 00 00
00 00 00 00 00 1E B4 02 74 00 00 00 00 FE 00 53
41 4D 53 55 4E 47 0A 20 20 20 20 20 00 00 00 FE
00 31 35 36 41 54 30 39 2D 48 30 34 0A 20 00 03
* Other names and brands are the property of their respective owners. *
Kevin_M_Intel
Hi maskedman,
Thanks for the information. Based on the report your computer is running with an older graphics driver version. Please uninstall the current driver following the instructions at this link:
http://www.intel.com/support/graphics/sb/CS-034574.htm http://www.intel.com/support/graphics/sb/CS-034574.htm
Once the driver is uninstalled, please download the latest driver at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22521
If during the installation of the driver you get notification/error messages, that message indicates that your computer manufacturer does not allow the installation of generic Intel video drives. You are required to install drivers from your computer manufacturer.
You may try to force the installation of Intel generic drivers by performing manual procedure, see here for instructions:
http://support.intel.com/support/graphics/sb/CS-022355.htm http://support.intel.com/support/graphics/sb/CS-022355.htm
This is the zip version of the video driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22520 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22520
In the case you do all this steps and issue persists, I recommend you contacting the Computer Manufacture for them to provide the custom driver for your system. It is also important to confirm if there is a compatibility issue between the Operating System and the game so contacting the game developer is a good idea.
