23527 Discussions
What graphics cards will work with Intel® Server Board S1200V3RPL?
JSart2
I'm running a EVGA Geforce 1060 on a Intel® Server Board S1200V3RPL, which has a PCIe x8 Gen 3 socket that i'm plugging into, but i just get random lines on the screen and the computer reboot loops endlessly.
The 1060 seems backwards compatible based on what i've read online, but i can't find anything conclusive. I've also read many times that a x8 should be ok, with minimal performance drop.
I've tested an older PCIe card (a Geforce 610) successfully and the onboard graphics works fine. I've switched the primary graphics card in the BIOs, have power plugged in and the screen is plugged into the right card, etc.
The PSU is a silver stone 500w, which should be enough power to at least boot (spec suggest 400w min PSU), i've tested without plugging in the 6pin power adapter and get a clear (i.e. not just distorted lines) message saying to plug it in, tested two separate power cables.
To summarise:
  • The card itself works in another machine
  • A geforce 610 works
  • Primary graphics card disabled
  • Power is plugged in, PSU has enough poewr
  • Disabled PXE 1GbE Option ROM and PXE 10GbE Option ROM as per intel forums
Any ideas on how to get it working, or at least confirm which cards will work?
SergioS_Intel
Hello JSart2, Here is the list of several video cards tested with the Intel® Server Board S1200V3RPL: Brand Part number NVidia 03G-P4-2781-KR NVidia 06G-P4-2790-KR NVidia VCGGTX750T2XPB NVidia VCQK4000 NVidia VCQK5000-PB NVidia VCQK6000-PB AMD AX7750 1GBD5-DH Remember, that you can always check the list of compatible components with our serverboards checking the Intel Tested Hardware and Operating System List: https://serverconfigurator.intel.com/exodus/page?eventType=11&targetPageId=120224 Additionally, make sure that you have the latest firmware installed on your serverboard: https://downloadcenter.intel.com/download/27725/Intel-Server-Board-S1200V3RPL-S1200V3RPO-S1200V3RPM-Firmware-Update-Package-for-EFI?product=71384 Best regards, Sergio S. Intel Customer Support Technician Under Contract to Intel Corporation For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
SergioS_Intel
Hello JSart2, I am following your case and would like to know if you need more help Best regards, Sergio S. Intel Customer Support Technician Under Contract to Intel Corporation For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
JSart2
Thanks Sergio, sorry for not replying earlier.
I flashed my motherboard to the latest firmware, but then needed to reset my configuration and re-apply the steps above to get it to work.
I don't see the post screen still, but then my machine boots successfully.
Appreciate your time and help.
SergioS_Intel
Hello JSart2,
You are welcome.
Please let us know if you need more assistance or you if we can close this thread.
Sergio S.
SergioS_Intel
Hello JSart2, Feel free to contact us back in case you need more help. Best regards, Sergio S. Intel Customer Support Technician Under Contract to Intel Corporation For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
