23269 Discussions
What is BIOS entry key for Intel Desktop Board?
cforbes
I have test equipment (Spirent SPT-C1) that started reporting a chassis intrusion warning after being moved to a new facility. Motherboard shows Intel Desktop Board (01) with sticker BQEP3410002L AA G12529-310. How do I remove this warning? How do I get into BIOS?
After the chassis intrusion warning (and a wait) it asks for a password.  I tried the spirent default password <Password removed> and a few others to no avail.  After 3 password failures it shows message:  http://support.intel.com/support/motherboards/desktop/ .
Board has a tan jumper on INTRL (3 pin header with unjumpered side labelled BIOS CFG I think).  Also has an unjumpered 2 pin header INTRD.  Is there a way to use the jumper/headers to remove the chassis intrusion warning?
AlHill
F2
n_scott_pearson
Chassis Intrusion is implemented as a feature within the chipset. It is a latch circuit. That is, when a short occurs across the pins of the INTRL header, the circuit is latched and remains latched until cleared. There is no way to clear the latch without going into BIOS Setup or using a tool.
As Al indicated, you use the F2 key to enter BIOS Setup. If, from there, you are unable to clear the latch, you can try doing so from the BIOS Maintenance Mode settings. Power off the machine, move the yellow jumper (or perhaps that's tan, there are different interpretations of that color and it (literally) fades over the years) from pins 1-2 to pins 2-3. When you then power on, it should automatically come up in BIOS Maintenance Mode. From here, you should be able to clear the latch and also clear the unknown password. When you are done, power off and restore the jumper to pins 1-2.
Now, I have seen cases where something fails and the latch will not clear from BIOS. I created a tool (a long time ago) that I could send you that you could use to try and clear this up. It is a 16-bit DOS tool, so you would need to boot MSDOS (or PCDOS or FreeDOS) from a floppy or USB flash drive and then run the tool. Let me know if you need me to send you this tool...
Hope this helps,
P.S. If you are responding to say you need the tool, don't include your email address in the response (unless you really want SPAM from all over the world). I can communicate with you using the Community's Private Messaging capability.
