22896 Discussions
What is the max refresh rate for intel uhd 630 graphics for 1920x1080
Amaid
I bought a AOC 24G4XE monitor that supports 180 hz I wanted to know if I could somehow maximise my refresh rate by using a certain cable I have intel uhd 630 graphics and I am currently unable to go higher than 120 hz on 1920x1080 as well as this my pc doesn’t have a display port so if I need that then could I get an adaptor?
IMMORTAL2077
It's 90Hz but yesterday my laptop is automatically changed graphics resolution on 1024 and refresh rate on around 72Hz. I thought this is error of debian but after so much digging on internet i found this is Intel's uhd graphics error. Reply me if you got any solution. Currently I'm stuck on booting screen with black screen and irc error
Amaid
For me personally the max right now is 120hz I’m just confused and wondering if I can get a higher refresh rate than 120 at 1920x1080 if I use a hdmi to display port adaptor
MUC
Honored Contributor I
UHD630 was introduced with Intel Coffee Lake processors. What the HDMI port can do depends on what other components the device manufacturer uses on the motherboard.
Therefore, please share information about the PCs you use.
Please run the Intel System Support Utility for Windows and perform a scan for all options. Attach the output file here.
Please also create a Report for Intel Graphics Drivers and attach the file here.
Amaid
i have attached what you have asked for hope this can help you find a solution. thanks
MUC
The device is an HP Pavilion All-in-One 24-xa0026na.
The only video output is HDMI 1.4
This enables the transmission of a video signal with a maximum pixel clock of 300 MHz TMDS.
1920 x 1080 @ 120 Hz (CVT-RB) = 285.55 MHz
1920 x 1080 @ 180 Hz (AOC 24G4 custom video timing) = 415.59 MHz
Unfortunately, you have to stay at 1080p @ 120 Hz. You can't go any further.
Amaid
Thank you for co forming I had a feeling that my pc was limiting it and I probably will upgrade soon. Thanks.
