22899 Discussions
Where to find changelog for Intel HD drivers?
RTruc
Hi. I am currently upgrading the Intel HD 64-bit drivers for the 4000 series. Where can I find a changelog for the changes made to version 3958 all the way from 3345? I am using Windows 7 64-bit.
Allan_J_Intel1
Thanks for joining the Graphics community.
Log files are available C:\intel\Logs
If you need to know driver history, you can get them through driver release notes
http://downloadmirror.intel.com/24329/eng/ReleaseNotes_GFX_15.33.30.64.3958.pdf http://downloadmirror.intel.com/24329/eng/ReleaseNotes_GFX_15.33.30.64.3958.pdf
Allan.
RTruc
Thanks a lot for the info. Now I can check recent driver installations and changes.
One question, is there a document which details Issues Fixed for a range of driver versions such as from 3154 to 3958? If not, what is the best way to open up release notes on all drivers in between 3154 and 3958?
Roger
Allan_J_Intel1
The best way to check driver information, known issues, solutions through driver release notes, this is available here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3712 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3712
Once you select the latest video drivers, on the top right hand side of the screen you will see a link for Release Notes.
Allan.
